We bit of a problem...
Old Sep 19, 2009 | 02:10 PM
skool u's Avatar
Default We bit of a problem...
I was doing a bit of cutting on the side wall to try and fit a turbo when I knicked the brake line that goes directly under the fuse box. I'm wondering if there is any way to put a compression fitting on there or do I really have to replace that entire hard line that goes from under the driver's side all the way to the passenger brake?
Also, is it just a simple matter of bleeding the one brake caliper when I do replace or reconnect the line?
Cheers for the help boys.
Old Sep 19, 2009 | 07:59 PM
negcamber's Avatar
You could probably make a compression fitting work. But it would be much better to just replace the line.
If the nicked line is leaking, you would probably need to bleed the entire system. More than likely all the fluid in the reservoir will drain out and that would mean the system needs to be bled.
trackrabbit21
Aug 11, 2015 11:14 AM
LoneStarS30Z
Jan 6, 2014 09:09 PM
Vinny_GPW-S2K
May 27, 2013 02:04 PM
MPS2000
Dec 2, 2011 06:50 AM
c32b
Mar 23, 2011 03:24 AM
