Weird bogging
Old Jul 22, 2016 | 08:28 AM
Lil Dre's Avatar
Default Weird bogging
so ive had this car for a while now, and its only done this maybe twice in 7 months or so. But when driving, sometimes the car will seem like it wants to bog under acceleration. it goes away shortly after. The most recent time I turned the car off at a light and it struggled to turn on, then it was completely fine after that. Im thinking possibly a clogged fuel filter? Unfortunately its harder to diagnose and issue that does not happen and im not sure if it will ever happen again. But looking for any opinions please
Old Jul 25, 2016 | 10:49 AM
Lil Dre's Avatar
bump....
Old Jul 26, 2016 | 06:53 AM
windhund116's Avatar
Last spark plugs and air filter change?
Thanks!
Old Jul 26, 2016 | 09:59 AM
Lil Dre's Avatar
Thanks!
Air filter was just changed. Im not sure about the spark plugs to be honest. I was told they were changed right before I bought the car, which was 5k miles ago
Old Jul 26, 2016 | 05:13 PM
Bruunz's Avatar
Hey,
Out of curiosity, does this feel like you have suddenly become a novice manual driver and the car begins to bunny hop?
I sometime gets this and i have clutch in and out to get the car behaving normally. Applying more throttle almost makes it worse without clutching.
Old Jul 27, 2016 | 05:04 AM
Micalbertl's Avatar
only thing I can think of
https://www.s2ki.com/s2000/shared/li...SB/a04-073.pdf
I would say this is worth a look
Old Jul 27, 2016 | 05:42 AM
Slowcrash_101's Avatar
Is it hot where you live? Welcome to the wonderful world of S2000 heat soak and accompanying ECU timing pull. Happens a lot, especially when it's hot and you've been sitting in traffic for a minute. A lot of people have this issue, the causes are many, the fixes are many, some people throw the kitchen sink at the problem and still have it. Car could need engine work, worn ECU, clogged fuel injectors, heat soaked battery, bad gas(more common than you think), spark plugs(not properly tightened), coil packs, wiring issues, MAP issues, dirty throttle body, dirty IAC and that's just for non DBW cars.
Old Jul 27, 2016 | 06:03 AM
Lil Dre's Avatar
Yeah. I live in FL. So its always 80-90 degrees here.
Lil Dre's Avatar
Originally Posted by Bruunz
Hey,
not on this car. My last car did tho
Old Jul 27, 2016 | 06:08 AM
How old is the battery? Maybe, start with new plugs. Relative cheap and you'll definitely know what mileage you have on them. Torque to 22-24 ft-lbs. I use NGK Platinum or comparable Iridium plugs in my Honda cars.
