weird brake problem..
Originally Posted by Wisconsin S2k,Feb 9 2006, 07:13 AM
just because all 4 tires might lock up simultaneously doesn't mean they won't work.
The ABS will kick in to unlock them since your rear wheels are still turning under the same grip (hasn't hit the speed bump yet).
If you're driving along at 30mph and suddenly you hit the brakes, and all 4 speed sensors go from 30 to 0, the ABS kicks in because of the sudden drop.
Originally Posted by xviper,Feb 9 2006, 08:14 AM
Hey T. Haven't seen ya here in a while. Don't be such a stranger.
Meebe I'll spring for an S2KI membership
Good taking to ya Dave
You could have one end, or corner of the car become light, lose grip and begin to lock a wheel or all four could become light, lose grip and begin to lock. It doesn't make sense that the wheel speed sensors would work in unison with one another.
Working independently makes more sense to me. The amount of grip or adhesion on a particular corner has nothing to with the rest of the corners.
For example, if the right front started to break loose but the rears as well as the left front were planted, why would those wheel speed sensors have anything to do with whether or not ABS engaged the right front
i think there are a few things we're losing in the communication here, but at the same hand I think I get what you're saying.
basically, the short of it is this. the ABS module watches each speed sensor for decelerations that are out of the ordinary.
i think you were saying that xviper implied that the speed sensors communicate directly with each other. but he never said that. in fact, if anything, he made the point that they are independent of each other, and the ABS module controls everything that happens based upon the readings it gets from the speed sensors.
The ABS has its own little brain and we can't be sure what sort of algarithms it uses to compute when "unlocking" should occur. I think it'll respond to a sudden change wheel speed and also any detectable differences in the wheel speed of one compared to another (particularly, decreasing wheel speeds).
