Weird Idle Issue
Old Aug 27, 2019 | 11:18 PM
artemiomedina's Avatar
Default Weird Idle Issue
Hey guys,
My idle was being a little funky on my ap2 (04) and idling around 1300-1500 warm so I cleaned out the iac valve and the idle returned back to normal. However, I noticed when the engine is spinning down after I put in neutral and the idle is dropping to idle at around 1-2k the idle raises 1-3 bars for a second or less before settling at the normal idle range. Is this normal? I didn't really notice it before when driving. Has anyone dealt with this issue? Should I try resetting the ecu? It doesn't do it all the time but enough to annoy me. Open to any suggestions. Thanks!!
Old Aug 28, 2019 | 02:15 AM
RolanTHUNDER's Avatar
Originally Posted by artemiomedina
Hey guys,
My idle was being a little funky on my ap2 (04) and idling around 1300-1500 warm so I cleaned out the iac valve and the idle returned back to normal. However, I noticed when the engine is spinning down after I put in neutral the idle drops and then raises 1-3 bars for a second or less before settling at the normal idle range. Is this normal? I didn't really notice it before when driving. Has anyone dealt with this issue? Should I try resetting the ecu? It doesn't do it all the time but enough to annoy me. Open to any suggestions. Thanks!!
It's somewhat normal for it to bog down a bit and then come back up to the targeted idle speed after many miles/years have passed but I noticed that mine doesn't do it anymore post DIY injector cleaning. That also produced better on road performance and smoother idle so I highly recommend you give that a try. You could reset the ECU now if you want to rule it out but I'm pretty sure the injectors need a good clean regardless.
Old Aug 28, 2019 | 09:29 AM
thanks so much for reply dude! its not really bogging its just raising a couple bars for a split second before idling normally so its super weird! I'll try resetting ecu and if not Ill try cleaning the fuel injectors. Car has less than 60k miles so its a little strange haha. Thank u again
Old Aug 29, 2019 | 12:42 AM
You're welcome. Hope it works out
HiPER
Mar 10, 2019 09:13 AM
Kadesryan
Mar 9, 2019 12:51 AM
ragtophardtop
Feb 24, 2019 09:47 PM
crucialenemies
Aug 5, 2018 11:15 AM
Kyle
Jul 23, 2018 11:51 AM
