Weird noise from engine bay,keeps draining battery
Old Jan 21, 2005 | 06:56 AM
Anthonymv's Avatar
Default Weird noise from engine bay,keeps draining battery
My roommates informed me that my car was making weird noises. Hours after I had driven the car it sounded like something was running and it was coming from more of the front of the car. My first guess was the water pump that comes with the Vortech SC. Has this happened to anyone before? My battery died 2 days ago and now I know why. For last night, I decided to disconnect the battery to save it and the noise stopped. Anyone have any ideas or similar experiences?
Thanks
Anthony
Old Jan 21, 2005 | 07:43 AM
xviper's Avatar
Has this been doing it since the install or just lately? Your water pump relay may be stuck with the main circuit ON. Double check the wiring routing to and from the relay. You might need a new relay.
Old Jan 21, 2005 | 11:14 AM
bigpurp's Avatar
I'm guessing it's your Vortech water pump. You can easily tell by sticking your ear close to the front grille. Check the relay like x said.
Old Jan 21, 2005 | 03:09 PM
Gernby's Avatar
Former Sponsor
Just disconnect the Vortech water pump and see if the noise stops.
Old Jan 21, 2005 | 07:57 PM
Slows2k's Avatar
I'd also check to be sure you didn't wire anything to the always on cavity in the underdash fuse box. I killed a battery wiring a wideband 02 gauge, by mixing up the cavity's in the fuse box.
Old Jan 21, 2005 | 07:59 PM
bigpurp's Avatar
Yep, I did the same thing.
Old Jan 21, 2005 | 08:01 PM
Slows2k's Avatar
I'm not the Only one
Old Jan 24, 2005 | 08:00 PM
Anthonymv's Avatar
It only happened this once and I've had the kit for months. Yeah, I disconnected the battery to save it from dying again and weird enough, the noise has not come back. I think it was definately my water pump and if the problem comes back I'll do what you siad xviper.
thank you
-Anthony
Fontal
May 26, 2013 01:42 PM
04S2kSS
Dec 11, 2009 12:09 PM
boszyen
15
Aug 28, 2009 03:09 AM
TheCarGuy2021
Nov 14, 2006 04:51 PM
Yellow Streak
Feb 24, 2003 01:17 AM
