Weird Throttle Response
Old Jul 31, 2010 | 09:05 AM
murd0x's Avatar
Default Weird Throttle Response
Alright guys ive looked around and couldnt find after 15 pages of looking some one with a similar issue im having maybe i was looking up with the wrong key words but for the past couple weeks my car has been acting very strange like when I try to give it gas to pass over or just pick up some speed it very sluggish and when i noticed that i tried to go WOT to see if would pick up but all it would do was just sound like its WOT but not go any where but when i give it a little bit of throttle i would say like an inch or 2 from the top it would pick up faster than WOT and accelerate as if i was giving it gas. So whats wrong here????
Also if im just moving around in slow traffic in gear like 1st or 2nd and not needing to brake the car would stutter hard if i attempt to give it some gas.
Old Jul 31, 2010 | 09:40 AM
ChefJ's Avatar
sounds sensor related. Possibly the MAP or TPS. I am sure one of the gurus will jump in but check those out, make sure the connections are good.
Old Aug 1, 2010 | 10:23 AM
murd0x's Avatar
come on gurus i need help please
Old Aug 1, 2010 | 10:28 AM
ChefJ's Avatar
did you check those sensors yet? no dtc's being thrown? vacuum lines all look good?
Old Aug 1, 2010 | 11:35 AM
ap1_tot's Avatar
no cel?
Old Aug 4, 2010 | 09:27 PM
murd0x's Avatar
ya i pulled them the other day and ive had the usual p0411 and p0420 but today i pulled them again and i got p0170 and p0172
Old Aug 5, 2010 | 12:18 AM
Eluded's Avatar
turbo lag?
Old Aug 5, 2010 | 08:03 AM
fatjoe10's Avatar
Originally Posted by Eluded,Aug 5 2010, 03:18 AM
turbo lag?
The turbo pulley may be slipping.
Kidding aside, sounds like a TPS issue to me.
Old Aug 6, 2010 | 08:12 AM
180tumbleweed's Avatar
TPS. Get one from OMNI POWER for a b/d/h/f series and dremel the flanges off to make it fit. then clock it correctly and tighten it down.
there should be a DIY for it on here.
-Chris
Old Aug 19, 2010 | 05:20 PM
murd0x's Avatar
I forgot to post this up but work and having my friends and family drive me around has given me a handful but ya i noticed today when i tried to test out my TPS with a multimeter that unlike in the TPS fix thread where the TPS is clocked in like a 5 o'clock position and mine is clocked into a 2 o'clock position could the position its in be the problem cuz i got my car like this last year and it ran fine til now
