Weird tick at idle.
Took off belt again to check pulley and all pulleys spun without anything noticeably bad.I also went ahead and took off valve cover forgot to record/take photos but all retainers and keeper showed no sign of cracking and nothing loose underneath valve cover; spun the crankshaft to see if anything was out of spec or moving (didnt see anything.)
I think it is for sure something that went bad in the block area so yeah that sucks but it was a high mileage motor and I definitely had a lot of fun with it. So now I think its time to save up for new motor just in case.
Most likely rod bearing going out.
I just watched your video now and immediately when I heard the sound I knew it wasn't valve, TCT or chain related but that it sounded like something much worse (rods/bottom end related). Sorry to hear it's a rod failing. Has the engine ever been starved of oil for an extended period of time?
I don't think rod knock is normal wear — unless the engine has a bazillion miles on it. It's prolly a sudden, critical loss of oil pressure.
