what is this for?
Old Nov 9, 2013 | 12:42 PM
s2kneub's Avatar
Default what is this for?
i don't have a picture, but on my 01 s2000, when i remove the front plate on the block that houses the timing chain, there's a visible, egg shaped coolant port that requires a special o-ring because it continues into a small cavity in the timing chain plate itself. the port is on the left side, if you're looking at it from the front obviously, right next to the oil filter port. anyway, my question is wtf is this for? is it a maintenance port of some sort? and why does it continue into the timing chain plate?
Old Nov 9, 2013 | 06:30 PM
Nutterbutter's Avatar
Oil passage. Feeds the main bearings.
Old Nov 9, 2013 | 06:51 PM
s2kneub's Avatar
oh ok, cool. and it pokes out into the timing chain cover why exactly?
Old Nov 9, 2013 | 06:57 PM
s2kneub's Avatar
also, when i pulled the cover, the o-ring was pretty much eviscerated for some reason. i'm guessing that doesn't bode too well for the life of my motor, huh.
Old Nov 9, 2013 | 08:53 PM
The timing cover just seals the end of the passage there is a threaded plug on the other end. Most likely honda left the passage open on both ends to allow cleaning of the block after machining. Replace the o-ring with a new one. They are like $3.
spessx
Apr 16, 2024 11:49 AM
Jstone_ap2
Sep 15, 2011 07:20 PM
Deception
May 16, 2011 10:34 AM
wthbtw
Sep 12, 2003 07:28 PM
