What can be polished?
What all can be covered in our cars?
I know that you can do the valve cover and intake manifold but can you also do the throttle body and more?
I'm guessing you would do it like any other job just start sanding it down from 200 grit to 2000 grit paper right?
Thanks!
Pictures would help as well a lot!
Thanks!
Thanks!
Thanks!
Now it's time to polish the tranny and engine block.
Sideway: the bay looks super clean, I saw it in person before(at wendy's house) and it just keep on looking better.
I polished load of stuff too, pretty much all the aluminum piece could be polished pretty easily. for the VC, i stripe off the paint before sanding, i use 220 first and then 400 and then 1000, make sure you get the wetsand grade sandpaper not the wood shop special =P
Originally Posted by basslover911,Dec 10 2006, 09:38 PM
^ CAN THE SPARK PLUG COVER BE POLISHED TO??
This is because I see people with them polished... or maby its that chrome spray that duplicolor has??
Originally Posted by Stratocaster,Dec 11 2006, 12:14 PM
Yes. There are a few out there. It is Aluminum, just like the valve cover.
well, time to check it out
