What causes VTEC to not work?
Old Sep 4, 2007 | 05:31 PM
REVZ TO9's Avatar
Banned
Default What causes VTEC to not work?
......besides low oil and a bad vtec solenoid?
Old Sep 4, 2007 | 05:53 PM
RED MX5's Avatar
Insufficient oil pressure, insufficient coolant temperature, plugged screen in the valve assembly, bad wire going to the selenoid, blown fuse, anything that causes the ECU to go into limp mode ...
Basically, if you have oil pressure and it is getting to the valve, and you also have voltage getting to the selenoid, then VTEC has to engage. When the valve lets the oil past, the pins only have one place to go.
Old Sep 4, 2007 | 06:18 PM
REVZ TO9's Avatar
Banned
gottcha, thanks!
Old Sep 4, 2007 | 06:32 PM
NVMY4N's Avatar
Also one that happened to me.
Clogged Cat. FTL
Old Sep 4, 2007 | 06:38 PM
ChefJ's Avatar
MAP sensor reading more then 10 psi.
Missing vtec pins due to poor cam and rocker installation.
Old Sep 4, 2007 | 07:37 PM
negcamber's Avatar
I've seen this...very tough diagnosis.
Old Sep 4, 2007 | 08:02 PM
Shovell242's Avatar
cold mornings after startup
Old Sep 4, 2007 | 09:30 PM
Mister Jew's Avatar
VSS well on a bseries motor atleast
Old Sep 5, 2007 | 12:33 PM
velocityracer's Avatar
Low v-tec fluid.....you better change it
jk hahaha.....couple things could be wrong
Old Sep 5, 2007 | 04:05 PM
RED MX5's Avatar
I've heard of it, but thank goodness I've never had to diagnose it.
Of course, once you know there is sufficient oil pressure getting to the pins and the pins still aren't engaging, that's probably a good clue that something is causing the pins to jam. Of course there's no telling how long it might take to realize that seemingly obvious fact. LOL, if the diagnosis was being done here, on line, there is no doubt that the owner would neglect to tell us that there had been some recent engine work.
