What to check...?
Old Sep 20, 2009 | 01:57 PM
ROTFLMAO's Avatar
Default What to check...?
Hi All,
I am at about 18k miles on my '07. I just replaced my diff, tranny and engine fluid (I had also recently replaced my air and cabin filters). What else should I be checking on the car? I am new to DIY and had previously relied on stealerships to check everything for me.
Old Sep 20, 2009 | 02:26 PM
RedY2KS2k's Avatar
Why not look at the recommended maintenance chart in the Owner's Manual?
Old Sep 20, 2009 | 04:46 PM
Kirpich's Avatar
^Agree.
Other stuff - if it ain't broke, don't fix it. Just enjoy! Oh, keep an eye on oil level, tire pressures, and cops.
Old Sep 21, 2009 | 11:26 AM
ROTFLMAO's Avatar
Thanks all.
Old Sep 21, 2009 | 12:26 PM
dammitjim's Avatar
This and replace your brake fluid every 1-2 years.
What diff fluid did you use? Make sure you didn't get VTM-4 from your dealer, it is designed for CRVs and will kill S2k diffs.
Old Jan 4, 2010 | 11:33 PM
niptek's Avatar
hmm. VTM-4? I just got an s2k and the previous owner had diff fluid changed at a honda dealer. you think they might've used VTM-4?
Old Jan 5, 2010 | 04:02 AM
dammitjim's Avatar
There is a good chance they did. If you can't find out for sure I'd stop driving it until the correct fluid is put in there.
It's an easy diy with a few tools.
Old Jan 6, 2010 | 05:37 PM
niptek's Avatar
imma call and ask....
Old Jan 6, 2010 | 06:22 PM
samsam5886's Avatar
Check the oil at least every time you fill up at a gas station. I believe that's what the manual says. And given all the engine failures people have seen due to low oil, it's the absolute best thing you could do to ensure a long life for your car.
I check it about once every week and there were countless times where I caught the oil level getting lower after driving hard.
Old Jan 6, 2010 | 06:23 PM
JDMQuip's Avatar
I would just change it for peace of mind. Parts should run no more than $15 given you have the tools to do it. I believe it's a 23mm for the drain bolt and 21mm for the fill? I can't remember.
