What to consider when lowered?
Old Feb 14, 2007 | 10:09 AM
ohms2k's Avatar
Default What to consider when lowered?
ok i got my espelir springs...ordered motor klasse shaft spacers (due to issues with cv on the ap1's)...will have them all installed in the spring and then i will go to alignment...I wanted to make sure if iam doing the right things? ...please correct me if there is anything else i need to do...to have a proper lowered car..thank you
Old Feb 14, 2007 | 11:00 AM
beanolo's Avatar
Umm.
Install.
Alignment (should include adjusting toe/camber)
and I believe you are good to go.
Old Feb 14, 2007 | 11:02 AM
iDomN8U's Avatar
Get Koni Yellow shocks? It will help in the long run.
Beanolo: What car is that in your sig?
Old Feb 14, 2007 | 11:06 AM
beanolo's Avatar
Shocks are always good. But the stocks aren't bad either, on a small drop. It can always be replaced later.
car in the sig is a 71' skyline gtr
Old Feb 14, 2007 | 11:15 AM
plokivos's Avatar
stretching before getting into the car and pre-stretching to make sure you don't pull anything when you get out of the car?
Old Feb 14, 2007 | 11:24 AM
ohms2k's Avatar
yea the koni yellows are great shocks...but right now i got 2 sets of shocks so after the first set blow...i'll consider koni's...so it seems like iam good to go....no more suggestions guys?
Old Feb 14, 2007 | 11:26 AM
beanolo's Avatar
Not sure what other suggestions you are looking for, its pretty straight forward.
Old Feb 14, 2007 | 11:27 AM
ohms2k's Avatar
well for example i just recently found out about the drive shaft spacers...and that seems like a must if you lower the car...so you don't get vibrations from the drive shaft stretching....so i was just looking if there is anymore of these must thing to do for a lowered car
Old Feb 14, 2007 | 11:29 AM
beanolo's Avatar
To be honest even I haven't installed the spacers.. and been driving lowered for almost 4 years now without any probs.
Old Feb 14, 2007 | 11:32 AM
ohms2k's Avatar
yea i know...iam just doing it to be on the safe side...it all depends on how you drive...where you drive..etc...what are you dropped on?
