What do I need to do a AP2 tranny swap?
Old Aug 22, 2010 | 08:58 AM
EK9MAX's Avatar
Default What do I need to do a AP2 tranny swap?
Is it just as easy as getting an ap2 tranny and swapping it over?
Do I need any other parts?
Old Aug 22, 2010 | 09:01 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
The rear flange off your AP1 trans. That's it.
Old Aug 22, 2010 | 03:36 PM
buzz944's Avatar
do you know the part number for the flange?
Old Aug 22, 2010 | 06:54 PM
rphdiesel's Avatar
What is the difference in the flange? Possibly the bolt diameter?
Old Aug 23, 2010 | 12:06 AM
s2000maniac's Avatar
is it really worth al the hassle just to change over to ap2 trans? why not just get a ap1 trans?
Old Aug 23, 2010 | 12:45 AM
omairtheman1's Avatar
Carbon synchros and revised ratios work well with the redline of the AP1
Old Aug 23, 2010 | 03:25 AM
ahhh I see, well then if I do end up changing my trans. then it would AP2 1.
Old Aug 23, 2010 | 06:08 AM
ChefJ's Avatar
If yo ustill have your ap1 trans just take the flange off the back. I am guessing you don't know what billman was talking about though. I believe there are 8 bolts in the ap2 flange vs. the 6 on the ap1 I could be wrong but again someone will chime in.
The flange we are referring to is what holds the driveshaft in place that connects the trans to the diff.
Old Aug 23, 2010 | 06:16 AM
Billman250's Avatar
Top Answer: 1
Each flange is 6 bolts.
The AP2 uses bigger bolts. So you will need the AP1 flange off you old trans so it will accept your current smaller driveshaft bolts.
Old Aug 23, 2010 | 07:04 AM
rphdiesel's Avatar
Thats what I am finding. It uses bigger bolts.
I knew something was different. I cought me by surprise.
