What does EPS mean on the dash?
Old Nov 16, 2005 | 05:49 AM
mavericckk..'s Avatar
Thumbs up What does EPS mean on the dash?
Went back this morning and whack the Map sensor. Reset the ECU. And did the idle reset thing. Where i ran the car at a consistent 3000rpm until the fan came on. Now the EPS comes on in the dash. What does that mean?
Old Nov 16, 2005 | 06:14 AM
Sideways's Avatar
Electric power steering.
Old Nov 16, 2005 | 07:57 AM
Squeezer's Avatar
its a safety thing, if you rev the car for a minute or 2 like that, it will set the EPS. you can reset it with a piece of wire according to the service manual instructions.
Old Nov 16, 2005 | 08:37 AM
Trip's Avatar
Old Nov 16, 2005 | 02:42 PM
Slows2k's Avatar
[QUOTE=Squeezer,Nov 16 2005, 11:57 AM] its a safety thing, if you rev the car for a minute or 2 like that, it will set the EPS.
Old Nov 16, 2005 | 02:47 PM
zcarcrazy's Avatar
Squeezer is right, if the engine is reved for a prolonged period the EPS will come on. It happened to me after cleaning the fuel system. I drove it around the block and it went off. You could feel the difference in the steering while the light was on.
Old Nov 16, 2005 | 02:52 PM
mikegarrison's Avatar
Yes, this is correct. If you rev it in neutral for a prolonged time, the computer decides that maybe the speedo is broken. Since the EPS relies on the speedo input, it shuts down the EPS.
A very short drive is all it takes for the EPS fault to reset. The light will go off and your power steering will work again.
BTW, the "idle learn" process is supposed to be IDLE learn. You aren't supposed to be revving it.
Slows2k's Avatar
EPS light= EPS DTC
I've idle learned several cars, and never set a EPS DTC
Old Nov 16, 2005 | 02:54 PM
Slows2k's Avatar
Can't say that i've ever seen that. Now I'll have to try it on a car.
Old Mar 31, 2015 | 03:35 PM
soFlo's Avatar
It says have to maintain a 3k rpm how can i do so without revving it? Sorry just got this problem and also new to this site
