What to grease when changing clutch?
Old Mar 21, 2005 | 05:16 AM
Touge Freak's Avatar
Default What to grease when changing clutch?
Do I grease the fork that goes on the throwout bearing. I have a slight chatter noise when pressing gas pedal in slightly. It is not the clutch buzz b/c when I let off of the gas completely there is no rattle at all. If I need to grease the throwout bearing and fork can I just remove the slave cylinder and go through that hole to lube the fork? Thanks for any help.
Old Mar 21, 2005 | 07:20 AM
Anyone know?
Old Mar 21, 2005 | 03:17 PM
Slows2k's Avatar
The OEM lube is High temp Urea grease.
Old Jan 20, 2009 | 03:01 PM
ChefJ's Avatar
What parts need to be greased? or should I grease pretty much everything that isn't friction/clutch related i.e. input shaft throw out bearing flywheel bearing....
Old Jan 20, 2009 | 05:37 PM
Ultra_Nexus's Avatar
I'm not too sure about that grease.
I have just had to service a friends S who was complaining of a dead clutch.
Now I had changed the clutch fluid a couple of months ago, so I knew it wasn't that.
Had a look at the clutch fork and the high temp grease had been used.
Turns out it doesn't like the cold weather and had turned into a very sticky substance - high viscosity and was causing the clutch fork to stick.
I used some wd-40 to plaster the fork hinge and hinge socket, then went about removing the old grease.
I then used copper grease (which I have never had issues with), fitted it back in - BAM - clutch like new!
ChefJ -
Take off the slave cylinder and you will see the clutch fork sicking out.
Grab hold of the fork and give it a good pull - it will pop out, but you won't be able to get it out of the gearbox casing.
If you shine a light in there, you will see that the fork is a basic hinge/socket design.
Simply grease the hinge (But don't go bonkers with grease - a thumbnail sized blob will be ample. You may have to use a screwdriver/coathanger to get the grease on. If you have long fingers, you could use your finger.
That is a basic pic of the clutch fork. The bit in red is cylindrical and is the hinge. If you greae that, you are done
Old Jan 20, 2009 | 06:14 PM
ChefJ's Avatar
Thanks for the advice. I actually have the tranny lying on the floor in the garage as I am reassembling after a clutch change. I live down in GA where it is currently cold as f*^& but termperatures are generally quite mild to very hott in the summer. I just want to make sure I grease the necessary things up before I start putting everything back together.
Old Jan 20, 2009 | 06:19 PM
Sorry if I sounded a bit patronising then - just wanted to be complete with the instruction
I'll have to ask you for advice for getting the top bolts off on the Gearbox when I come to my clutch change
Old Jan 21, 2009 | 09:52 AM
SpitfireS's Avatar
Old Jan 21, 2009 | 12:47 PM
ChefJ's Avatar
^ perfect thanks.
Old Jan 23, 2009 | 06:51 PM
Opposite_Lock's Avatar
Grease the outside groove of the throwout bearing too.
