What is LSD??
Old Jan 28, 2002 | 08:13 PM
vaio9003's Avatar
Default What is LSD??
Hi,
I am only a new driver for a sport car like this, can everyone tell me what LSD is, and what's the different if I using 1 or 1.5 or 2 way??
Is that good for driven??
Thank you very much!!
Old Jan 28, 2002 | 08:26 PM
pfb's Avatar
pfb
Timothy Leary's dead...
Old Jan 28, 2002 | 08:33 PM
AVXs2000's Avatar
welcome
you should check out the FAQ
Old Jan 28, 2002 | 08:35 PM
AVXs2000's Avatar
it is Limited Slip Differential
s2000 one is made by Torsen
Old Jan 28, 2002 | 08:49 PM
AVXs2000's Avatar
can not believe no one want to explain what is a LSD
LSD is part of the transmission. when you make a turn, the wheel in the outside cover more distance than the wheel in the inside. the out side wheel have a hard time to follow the in side wheel. the LSD just adjust the torque between wheels, so it wouldn't slip
Torsen LSD is fully mechanic, so i dont know what you mean by using 1, 1.5, 2 way
Old Jan 28, 2002 | 08:57 PM
AusS2000's Avatar
A diff is the device that allows one wheel to turn more than the other when a vehicle turns. The torque (or turning power) is shared between the two wheels (rear wheels in the case of the S2000). If one turns more (outside wheel) the other (inside) turns less. The problem with this set up is when one wheel breaks traction (hits water, oil, gravel, or just too much torque) and starts to spin, no troque goes to the other wheel and the tyre tracks aren't very impressive .
What a LSD does is sense when one wheel is spinning more than the other and locks up the differential. Conventional LSD's use a clutch type mechanism that winds up when there is a difference in rotation of the two wheels and locks the mechanism. But the Torsen Diff as used in our S has a set of mechanical screws linking the two wheels that, due to their angle and ratio, don't particularly like to spin. As a result, even when one wheel has lost traction some torque is still applied to the other and you won't be stranded.
QED
Oh, BTW, do a search on Torsen on this board. There are some great diagrams from a recent discussion.
Old Jan 28, 2002 | 09:02 PM
jzr's Avatar
jzr
Hehehee
[QUOTE][B]Is that good for driven??
Old Jan 28, 2002 | 10:57 PM
vaio9003's Avatar
"At Spoon, we employ a 1.5-way, mechanical-type of LSD"
That's what I saw from a Spoon page.
I also heard from someone that if U want to put a new LSD, and can use for 1 or 1.5 for a beginner if u
want to learn how to drive....
What's value here stand for??
Well, I know it may sounds stupid here, but I really dunno and that's why I asked this questions.
Thank you for all of the serious reply here. =)
Old Jan 29, 2002 | 12:18 AM
AVXs2000's Avatar
[QUOTE]Originally posted by vaio9003
[B]"At Spoon, we employ a 1.5-way, mechanical-type of LSD"
Old Jan 29, 2002 | 05:55 AM
VisualEchos's Avatar
You may need new, beefier parts for your LSD if you have a supercharger/turbocharger, but the Torsen (which is the design not the manufacturer, literally means "torque sensing") is the best LSD design in existence. I'd leave it if I were you, don't fix it if it ain't broke, and if it breaks replace the part that broke with a stronger part...not the diff.
Andrew
