What maintenance should i do?
Old Apr 23, 2012 | 06:46 PM
S2000perez's Avatar
Default What maintenance should i do?
Ok i got an ap1 w/ 80k miles on it last major service was done at 60k and jst changing oils n filters from there on... What maintenance service should i do? Plus whenever i start my s2000 i push d start button and it sounds like its stuck there but i only pushed it for like one second... And there are instances too that after a short drive around and i turn off the car for a few mins, the car jst wont start right back up, as if the battery is dead, take note the battery is less than a year old... Pls advise ty
Old Apr 24, 2012 | 04:30 AM
redwing497's Avatar
Welcome to the forums. As for your last concern, I think it's just the car. My 2007 with only 37k on it does the same thing a lot of the time. As far as maintenance, all fluids is a must along with some other things:
-Oil change
-Transmission Fluid change
-differential fluid change
-Brake fluid change/bleed
-clutch fluid change/bleed
-Intake air filter
-VALVE ADJUSTMENT (inspect retainers while in there)
-Also consider cleaneing the injectors, IAC Valve, perform "MAP whack"
Also, read the second post in this thread:
What to look for when buying a used S2000
Good Luck!
Old Apr 24, 2012 | 05:15 AM
dwight's Avatar
Oil:
https://www.s2ki.com/home/2008/12/01/diy-oil-change/
Diff:
https://www.s2ki.com/s2000/topic/348...-fluid-change/
Trans:
https://www.s2ki.com/s2000/index.php...22&t=565855&st
Brake Fluid:
https://www.s2ki.com/s2000/topic/482...t__p__10329320
http://forums.clubrsx.com/showthread.php?t=540550
Clutch Fluid:
https://www.s2ki.com/s2000/topic/924...t__p__21351508
Air Filter:
Didn't find a nice link.
Cabin Air Filter:
http://forums.s2kca.com/showthread.p...-How-To-Change
Rear Axle Nut Retorque:
https://www.s2ki.com/s2000/topic/929...e-nut-tsb-diy/
Some other stuff:
https://www.s2ki.com/s2000/topic/548...d-maintenance/
Oh yeah, and coolant too. Use Honda coolant.
https://www.s2ki.com/s2000/topic/818...h/page__st__25
Pineapples
Apr 20, 2011 07:02 PM
smrtgi
Dec 20, 2010 05:23 AM
Bob A (SD)
Aug 26, 2008 02:56 PM
comets
Feb 5, 2004 04:35 PM
allkingz
Jul 17, 2003 12:37 PM
