What is this noise?
Old Dec 13, 2013 | 01:34 PM
1SIKAP1's Avatar
Default What is this noise?
Plese help me identify what is causing this noise. It started yesterday comes and goes, no code runs fine?tct??
[media]http://youtu.be/mvNhT1pPLd0[/media]
Old Dec 13, 2013 | 02:46 PM
s2000maniac's Avatar
Take off the drive belt and turn the car on. If the noise goes away then it's one pulleys or tensioner that's gone bad. If the noise doesn't go away then you got an internal problem.
Old Dec 13, 2013 | 03:18 PM
1SIKAP1's Avatar
How would I remove the drive belt?
Old Dec 13, 2013 | 04:43 PM
Steps 1-6 for drive belt removable and install.
https://www.s2ki.com/s2000/topic/769...rpentine-belt/
Old Dec 13, 2013 | 05:41 PM
jkelley's Avatar
I don't think you can (or should) run the car without the serpentine belt for very long.
Also, doesn't the belt run the other pulleys? So only the one would spin without the belt making you not able to check the others?
Maybe try using a mechanical stethoscope on each pulley first (with the belt on). I think there's one that may fail more often than others (alternator pulley?)
I'm not super knowledgeable on this kind of stuff, just trying to help.
Old Dec 13, 2013 | 07:13 PM
He only has to run the engine for 5-10 secs just to varify the noise. No harm will be done.
Old Dec 13, 2013 | 07:18 PM
darcyw's Avatar
doesn't sound like typical TCT. I'd say that sounds more like one of those pulleys on the front of the engine from your video.
good luck
darcy
Old Dec 14, 2013 | 09:20 AM
1SIKAP1's Avatar
im thinking it might be the belt tensioner? the sound comes right from pulley/tensioner, is there any way to test it before I replace it? running the engine without the belt sounds a bit sketchy?
Old Dec 14, 2013 | 09:42 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Sounds like the AC compressor bearing, I've heard it before. Definitely no TCT noise there.
Take the belt off and spin it by hand.
Old Dec 14, 2013 | 04:40 PM
silverstone05's Avatar
i second billman
