What spark plugs?
Old Oct 8, 2007 | 04:36 PM
screaminyellow's Avatar
Default What spark plugs?
Hey guys, I have an MY '02 with 82,000 miles and I just realized that the spark plugs have never been changed
So my question is.... What plugs should I be using? I drive the car hard and track it once in a while. I have some mild mods like intake, exhaust catch can and so on.
Old Oct 8, 2007 | 04:38 PM
Slows2k's Avatar
The OEM plugs don't need to be changed until 105K.
No need to freak out that they haven't been. OEM NGK plugs are hard to beat for an essentially stock NA car.
Old Oct 8, 2007 | 04:48 PM
Wow, quick reply. Thanks alot. I think I might change them any ways. So the stock NGK's are the way to go!?
Old Oct 8, 2007 | 04:51 PM
Slows2k's Avatar
Yup. They stock plugs are just fine. As long as they are tightened to spec they don't give any problems.
Old Oct 8, 2007 | 04:54 PM
2poor2mod's Avatar
you should also check to see if they have been replaced under the recall or not, if they haven't you may be able to get them changed out for free
Old Oct 8, 2007 | 05:04 PM
DaRAVENS2K's Avatar
It sounds like you got almost the same set up as me and I really noticed some Real power Outta some boshe Plats +2s even over the stock NGKs. I just thinks it because of the set up the honda eng. where the spark is more directed sideways and getting more power outta the plugs
Old Oct 8, 2007 | 06:21 PM
Almostlude's Avatar
to Bosch, Search around and find out why..... NGK 4 life
Old Oct 8, 2007 | 07:24 PM
Antonov's Avatar
changed mine @ 40k for good measure, they were ready.
Old Oct 8, 2007 | 08:05 PM
What is the correct torque setting for them in Ft.\Lbs. please?
Old Oct 8, 2007 | 09:01 PM
roondawg's Avatar
