What tools do i need?
Old Jul 31, 2006 | 04:39 AM
j85rsxtypes's Avatar
Default What tools do i need?
Guy im getting my car soon and i made up my mind and i'm getting the invidia exhaust, if its too loud for me i guess i'll just try to sell it, i just have to have it tho or its going to bother me for ever, but know my ???? is what tools do i need to install this exhaust , or should i just take it to a local shop, i rather do it my self tho. thanks
Old Jul 31, 2006 | 09:07 AM
NFRS2kSi's Avatar
1)u need 2 14mm socket or wrench. i prefer using socket than wrench for more grip.
2)jack and jack stand to raise the car.
Old Jul 31, 2006 | 09:10 AM
payyourtoll's Avatar
check the FAQ for DIY on this and more
https://www.s2ki.com/forums/index.php?showtopic=108435
Old Jul 31, 2006 | 10:54 AM
XclusiveAutosports's Avatar
You'll need a jack, jack stands, set of sockets/ratchet, and a can of liquid wrench. Depending upon how rusted up your bolts are you might need an impact wrench. I installed an invidia a few weeks ago and the bolts were so seized up that an impact wrench wouldn't break them loose along with liquid wrench. I ended up having to cut the bolts, but hopefully yours won't be too bad.
Old Jul 31, 2006 | 12:04 PM
NFRS2kSi's Avatar
what the hell is liquid wrench?? is that a new term used for WD40?
Old Jul 31, 2006 | 01:23 PM
... its like WD40, but a different brand. I think its better than WD40 for using with seized or rusted bolts. Any hardware store should have it.
Old Jul 31, 2006 | 03:36 PM
negcamber's Avatar
And I've decided that PB Blaster is even better than Liquid Wrench.
Consider buying a used Invidia so you won't loose too much of your money when you decide you can't take the drone any longer (like I did).
Old Aug 2, 2006 | 08:53 AM
GotRPMs's Avatar
Pb Blaster ftw, works so much faster than liquid wrench.
Old Aug 3, 2006 | 03:38 PM
iam7head's Avatar
I rarely use those on my car, because i torque down every(if there's a spec availble from honda), use anti-seize on large bolt and there's no salt/rain around socal.
you might want to put some anti-seize on the exhaust bolt, they get hot and cool off everytime you drive the car, most of the time they are the one that seized one.
but for the tough job, silicon spray, torch, 5 foot breaker bar, 400lb impact gun and BFH will do
Old Aug 3, 2006 | 05:38 PM
r_duff's Avatar
10 mm for removing the sheild off the rear tie bar too.
