Whats going on?
2001 68k miles hks hi power exhaust, test pipe, aem cai, vafc II. The vafc II is set to stock for now since I need to save up for some dyno time. The car came with it and an air/fuel gauge. For some reason while I am in low rpms especially on a bumpy road the gauge drops to lean and the car bogs like it wants to die. Other times I can be driving along around 3to4k and and it will drop to lean for a sec and I can feel the car shutter for just a sec then go back to normal. I did have misfires in all 4 cylinders and random misfires. The light stayed off for months then just came back on.
I replaced the plugs and all my gaskets pertaining to the valve cover and spark plug seals. What should be my next step. Valve adjustment, map whack, new fuel pump and filter....?
What usually causes a car to run lean like this. I know I can feel a drop in power. Please offer any advice. Any questions please ask.
Thanks in advance.
Thanks in advance.
MAP and O2 sensor are probably the two prime things. Fuel pressure is secondary but, still something to watch.
I'd probably disconnect the VAFC and A/F gauge. Get it back to a stock baseline and see if the problem goes away.
We thought it was a crappy wiring job because one of the wires was loose. When you pushed on the wires the idle got stronger all of a sudden. We re did that part of the wiring and thought the problem was fixed. This was probably 5 months or more ago. Now maybe something else came loose. I will double check the wiring. I wouldn't mind just selling the thing but I don't want to have to mess with all the wiring involved.
If it is the O2 sensor or MAP would it throw a code? How expensive is it to fix those?
Yeah the dealer I bought the car from said it was adult owned owned and everything was professional installed and cared for. Now it makes me wonder.
Originally Posted by Kenpo_S2000,Jul 30 2006, 10:16 PM
P.S. is there a way to disable the VAFC and A/F gauge with out rewiring everything back to stock?
Viper that is what im worried about. If I find someone with some major electronic and car know-how should I be okay putting the wires back to stock??
Is it possible to leave the A/F gauge and remove the VAFC to get results. I never would of thought the A/F? gauge could be screwing with the car. You know your stuff so that is why I am asking. I will do what you think is best.
Thanks
Thanks
