Whats wrong with my VTEC?
Old Jan 19, 2007 | 07:41 PM
REVZ TO9's Avatar
Banned
Default Whats wrong with my VTEC?
My oil level is fine and I always wait for my engine to warm up before ever using VTEC. Plus, my clutch just got replaced because it was slipping bad. But why doesn't my VTEC feel as strong as it should be? Also, it sometimes kicks in at 7K and not always 6K! Why is that? Could I have a bad vtec solenoid? My AP1 is 7 years old now, but with only 56K miles, so do some things require changing out for me soon? What else contributes to vtec?
Old Jan 21, 2007 | 01:04 PM
snakeeater's Avatar
VTEC engagement point depends on load (rpm, throttle position. MAP). Odds are the VTEC solenoid is OK. Check your oil level and spark plugs.
Most likely the ECU has just learned that you have been babying it. Reset ECU and drive it hard for a while to re-teach it how to rev.
Old Jan 21, 2007 | 01:22 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Air filter...big effect on VTEC.
Map sensor...big effect on VTEC.
Old Jan 21, 2007 | 07:01 PM
trapper's Avatar
I'm curious...... is that because a clogged air filter would cause the MAP sensor to read a too low intake manifold pressure?
Old Jan 21, 2007 | 08:02 PM
TitusS2k's Avatar
Id say your Vtec selinoid is cloged with sludge, Id pull it off- Carefully remove the Seal/Gasket. Also remove the screen, Spray it out with brake cleaner and let it evaporate. Re-assemble then out it back on. Also Check your oil. Reset your Ecu while doing so...
artec12
Jan 2, 2016 12:45 PM
rasulrasulinho
Jun 24, 2015 06:24 PM
darkfx
Mar 24, 2006 08:32 PM
rehile
Feb 11, 2005 11:09 PM
t00kosher
Sep 16, 2004 04:57 AM
