Wheel bearing direction which side?
Old Jun 3, 2018 | 12:51 PM
weenrock's Avatar
Default Wheel bearing direction which side?
Hi,
I just bought 4 Timken wheel bearings to replace all 4 corners. Can someone confirm that the side with the black ring faces the car for the ABS to function correctly?
Cheers!
Old Jun 3, 2018 | 12:53 PM
fernando.'s Avatar
Use a magnet. The side that is conductive goes towards the inside.
Old Jun 3, 2018 | 05:59 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Black seal faces outward.
Silver metal seal faces inward.
Old Jun 3, 2018 | 08:03 PM
weenrock's Avatar
Thank you gents!
Old Jun 4, 2018 | 12:09 PM
cdelena's Avatar
This may be helpful.... https://robrobinette.com/S2000Bearing.htm
Old Jun 16, 2018 | 09:26 PM
weenrock's Avatar
Hi all,
Sorry to bring this back. I pressed 3 of the 4 bearings in. However, the 4th bearing has identical sides. There is no rubber seal on one side. I tried using a magnet to detect which side was which, but both were magnetic. Is there a proper way to figure this out or should I assume the bearing was manufactured incorrectly and get a new one? I've never seen one like this.
Mind you, I ordered 4 Timken 510050 wheel bearings. 3 of the 4 are stamped made in the USA, the fourth is made in Korea.
Old Jun 17, 2018 | 04:53 AM
EELPIE's Avatar
If you take a small paper clip and place it on the bearing one side will draw the paper clip to it. The other will not.
The bearing itself has a magnetic side.
Also I did some checking the Timken number I come up with is 510039 not 510050.
Old Jun 17, 2018 | 08:16 AM
rrounds's Avatar
P/N 510050 is the right P/N for my '06.
Amazon says 510039 in not for a '06 don't know about other years.
ROD
Old Jun 17, 2018 | 09:40 AM
EELPIE's Avatar
Well I do not know about Amazon.
But I do know if someone walked up to my station at NAPA I would sell them a SKF FW145 which crosses to a Timken 510039.
There are no S2000 applications for a 510050 which is a SKF FW45
Just early 2000s Acura TL's Cl's and Honda Accords
Old Jun 17, 2018 | 03:21 PM
rrounds's Avatar
RockAuto also says 510050 for a Timken bearing
https://www.rockauto.com/en/catalog/...l+bearing,1672
RockAuto also has a SKF bearing for the S with the FW145 p/n, you can check the SKF p/n page
SKF Online Parts Catalog
And Amazon still says the 510039 does not fit my '06 S
Amazon Amazon
ROD
