Wheel stud failire
Old Dec 24, 2015 | 06:14 PM
Twonius's Avatar
Default Wheel stud failire
I just drove my car again after my sister had been dairying it for a few months. I noticed a little vibration only when driving straight or turning left (went away when I turned right). So at my first stop I checked the front right tire and Lowe and behold 3 of the lug nuts were missing. When I jacked up the corner to look a bit closer i discovered the remaining 2 were finger tight
At first I thought I'd just lost 3 of them but when I tried to scavenge a nut off the back but the threads were too far gone
The power steering was replaced a few months back and I wonder if they just forgot to torque that corner which eventually led to the failure, or is there a more common cause?
Old Dec 24, 2015 | 06:23 PM
zeroptzero's Avatar
Improper wheel torque for sure, could have been too tight
Old Dec 24, 2015 | 06:30 PM
fernando.'s Avatar
Too loose more than likely.
Too tight will typically cause a sheering effect.
Old Dec 24, 2015 | 07:08 PM
99SH's Avatar
Looks like the shop forgot to tighten the lug nuts. I'd put a wrench on all wheels to verify it's indeed torqued properly.
Old Dec 24, 2015 | 07:28 PM
Twonius's Avatar
Yeah I made sure all the ones were gutentight before I drove home
Old Dec 24, 2015 | 07:34 PM
Twonius's Avatar
The missing ones did appear to be sheared off. My guess was as the wheel loosened maybe it started hammering on the nuts, It would be weird that two were finger tight and 3 were over tightened almost to failure
Old Dec 24, 2015 | 09:18 PM
99SH's Avatar
Do you know whether the shop used an impact gun or torque wrench? That's another possible cause.
Old Dec 25, 2015 | 01:21 PM
zeroptzero's Avatar
That is almost always the cause, they use impact guns rather than take 2 extra minutes with a torque wrench. It would be rare for them to leave several lugs loose and others tight. Whenever I get work done at a shop involving my wheels I come straight home and loosen all lugs and torque them to spec with a torque wrench. I don't trust anyone with lugnuts, I also want to avoid warped brake rotors.
Old Dec 25, 2015 | 02:26 PM
RLT's Avatar
RLT
The last few times I needed tires I just took the wheels off the car and dropped them off at the tire place. There are too many things that they can screw up.
Syn
Mar 5, 2012 05:45 AM
Ray_Dogga
Jun 5, 2011 10:45 PM
mikecl713
Sep 23, 2004 11:33 PM
douge
Jun 13, 2004 10:20 AM
SilverSurfer
Jun 13, 2002 10:46 PM
