when do you get the valves adjusted?
Old Oct 12, 2004 | 02:56 PM
wwwracer's Avatar
Default when do you get the valves adjusted?
I'm at 34k miles. At 30k i change the diff, tranny and cluth fluid. I installed my
comptech CAI to replace the old air filter. I didn't need brake pads because i installed the Spugen racing clay pads at about 27k. I just ordered the incabin filter for the AC which im going to replace within the week. I had my car aligned and its well within specs.
All i have left I believe is to change the coolant. My timing belts appear to be fine too. Please help if i left anything out?
I heard some places suggest the valve adjustment at 30K and others at 90K.
Old Oct 12, 2004 | 03:04 PM
SM00TH976's Avatar
your timing belt appears to be fine because it's a chain.
Old Oct 12, 2004 | 03:13 PM
wwwracer's Avatar
Old Oct 12, 2004 | 06:34 PM
S2KANDRE's Avatar
Old Oct 12, 2004 | 06:44 PM
koala's Avatar
Your coolant will be fine. If you had an '00-'01 MY I'd suggest considering replacement of the coolant, but on an '02 and up the coolant is an even longer-service version.
Valve adjustment is sometimes worth it, even when the car is fairly new. A lot of people have found the valves to be off by a fair bit even from the factory.
Otherwise, you've got basically everything covered. I had over 35,000 miles on my '01 and all I had completed was one diff. fluid change, regular oil changes, and just cleaned out the cabin filter (without replacing it).
Old Oct 13, 2004 | 10:08 AM
David1's Avatar
I had my valves adjust last month on my 02 at 9100 miles. # of the intakes needed adjustment. Car runs a lot better.
Old Oct 16, 2004 | 08:29 PM
Matt_in_VA's Avatar
Community Influencer
What is the recommended valve adjustment interval?
Old Oct 16, 2004 | 09:36 PM
PWRMKR's Avatar
Normal
The "normal" schedule is fine for most drivers, even if they occasionally drive in severe conditions.
105,000 mi/168,000 km
7 yrs Scheduled Maintenance
Severe
Follow the "severe" schedule only if you drive in one or more of these conditions most of the time:
Trips of less than 5 miles (less than 10 in freezing weather)
Extremely hot weather (over 90 degrees F)
Extensive idling or stop-and-go driving
Trailer towing, car-top carrier, or mountain driving
Muddy, dusty, or de-iced roads
I checked mine at 30,000 miles. No adjustmants were made.
Old Oct 16, 2004 | 10:08 PM
S2KANDRE's Avatar
so that 105,000 mile interval goes for most other cars too correct?
Old Oct 16, 2004 | 10:09 PM
S2KANDRE's Avatar
oh and approx how much is it to get done?
