when to put in synthetic oil?
Old Jul 14, 2003 | 06:46 AM
my2k2s2000's Avatar
Default when to put in synthetic oil?
just curious... when can i put in synthetic oil? i'm at 7500 right now.
Old Jul 14, 2003 | 07:04 AM
xviper's Avatar
If your car has been consuming quite a bit of oil (like 1-2 qts every 3000 miles) wait till this consumption has "tapered off". This should be starting to happen soon for you. Most will convert over sometime after 10K miles but each car is different.
Old Jul 14, 2003 | 09:05 AM
my2k2s2000's Avatar
i haven't vtec-ing that much. i checked the oil levels off and on and haven't notice any oil loss. so it's safe to say... use sythetic maybe around 13k.
Old Jul 14, 2003 | 09:09 AM
DarioManfretti's Avatar
That should be fine. Your manual says you can change over to synthetic around 10K.
Old Jul 14, 2003 | 09:19 AM
xviper's Avatar
[QUOTE]Originally posted by my2k2s2000
[B]i haven't vtec-ing that much.
Old Jul 14, 2003 | 09:28 AM
my2k2s2000's Avatar
kool... thanks.
Old Jul 15, 2003 | 03:29 PM
Tugz_S2K's Avatar
Banned
I switched over to Synth @ 5500miles/9000kms....
My car stopped consuming oil at 2500miles/4000kms
15,000kms now and engine purrs...
Old Jul 15, 2003 | 03:38 PM
MichaelB's Avatar
I'm curious. In which manual does Honda indicated that the use of synthetic oil is recommended AFTER 10000 miles? I have a 2001 that has been consumming rather copius amounts until just recently at 12000. At this point it seems to be using considerably less. Did Honda come out with some further directions concerning this problem AFTER the 2001 manual? Thanks
Old Jul 15, 2003 | 03:49 PM
RedY2KS2k's Avatar
I've got two copies of the '00 manual. (I bought the car used and found the manual in the car after I'd ordered one with the service manual - no, it wasn't in the "secret compartment".) Neither copy says anything about waiting to change to synthetic oil.
Old Jul 15, 2003 | 03:54 PM
Honda found out later that the engine consumes oil up to around 10K miles and had an addendum to the manual. I know that my '01 has it in there.
