where can i find the air pump?
It is located in the front drivers side just behind the bumper. It's the black just below the headlight in cfcraftings diagram. Its not as simple as which wire goes to the ECU. There is a relay as well as other controls to look at. If you intend to work on the car then by all means buy the S2000 Service Manual at the location noted. If not have someone that has the manual take a look...it will save you time and money.
Utah
Utah
