Where is the MAS sensor?
Old Jul 13, 2011 | 07:20 AM
Thomas Guide's Avatar
Default Where is the MAS sensor?
My S is idling high, it normally idles 800-900 rpm but lately has been 1100-1300 and I can hear the engine 'pulsing' slightly as it's just not in the right range.
I'm going to do a few things this weekend, change out air intake filter, clean out the IAC valve, do the MAP whack with zip tie down...BUT
Someone suggested I also clean out the MAS... can't find it, don't know where to look... can anyone advise with link or pics / part number so I can look in the HELMS. Do we even have one?
Thanks!
Old Jul 13, 2011 | 07:31 AM
raymo19's Avatar
Do you mean MAF sensor? If so the S2000 doesn't have one.
Old Jul 13, 2011 | 07:33 AM
Yes, I typo'd, MAF sensor.
So can I presume the MAF sensor is the MAP sensor? Is there another component like the MAF that I should be looking at cleaning?
Old Jul 13, 2011 | 07:40 AM
SgtB's Avatar
A MAF and MAP are different, but provide basically the same function. Our MAP is the square sensor on top of the throttle body.
For a high idle, I would listen for vacuum leaks, and possibly clean the IACV.
Old Jul 13, 2011 | 07:46 AM
I found a great DIY to clean the IACV as part of this weekend work I plan on doing:
https://www.s2ki.com/s2000/topic/492...ean-iac-valve/
Didn't think to listen to vacuum leaks... can you provide some pointers or a DIY link if you know of one?
thnx
raymo19's Avatar
Old Jul 13, 2011 | 07:52 AM
SgtB's Avatar
Just check around vacuum hoses. There isn't really a diy for that. If you changed anything lately check in that area and make sure you didn't forget to reattach a hose, or bumped something loose.
I read your op and noticed "pulsing". That's usually a leak. Check to see that there isn't a ton of carbon around the throttle plate. it may be getting jammed open slightly.
Old Jul 13, 2011 | 08:14 AM
As I'm trying to save a few bucks and do the items I listed in my OP myself, I'm learning a few things along the way. Can you advise if the throttle plate is in the IACV? Or is this in another location that I need to dismantle...
thnx
Old Jul 13, 2011 | 09:07 AM
JohnsS2000's Avatar
Vacuum hoses is my thinking. Had an Accord that one disconnect on that caused the car to pulse/surge
Old Jul 13, 2011 | 09:09 AM
So the pulsing is very minor, once the car is warmed up, it sits at about 1100 rpm and very gently I can hear it pulsing with it fluctuating to 1200-1300 rpm... after having the car for 55k and a lot of track days, I'm really in tune with the sounds it makes, I think someone else would not hear it, but it's like night and day to me.
