where is oil pressure switch?
Hello people I'm hoping someone can direct me to locating the oil pressure switch on my s2000 (2001)
Recently I had my engine replaced from a UK spec s2000 to a Japanese engine.
I am having problems with the VTEC system not functioning. I also have a check engine light appearing on the dashboard.
The error code I get is : P1259 (A problem in the VTEC Oil Pressure Switch circuit or VTEC Solenoid Valve circuit).
The UK dealer service manual states that the oil pressure switch is located under the VTEC solenoid attached to the engine, However my japanese engine doesn't!!!
Should it be the same as the UK engine or is the oil pressure switch somewhere else.
Regards
fame
Regards
fame
