Whining or Whaling Noice in Engine Bay
Old Sep 14, 2017 | 11:28 AM
dshea's Avatar
Default Whining or Whaling Noise in Engine Bay
What is this whining or whaling sound coming from the engine bay? It sometimes happens at idle and sometimes at around 2500 to 3000 RPM. At idle, it lasts about 1 second every 2 to 3 seconds. It stops after a minute or two once it starts. I recently washed my engine bay using a degreaser. No other relevant work has been done on it recently (new master and slave clutch cylinders, new throw out bearings, new spark plugs). I haven't tried anything other than spraying some lubricant onto the pulleys to see if that would fix it (it didn't, but it might have helped a little. not sure).
I'll try to upload a sound clip when I figure out how to convert the mp4 to mp3.
Old Sep 14, 2017 | 11:41 AM
dshea's Avatar
Default Sound clip of engine noise
Sound clip of the engine noise. I have the blinkers on for reference. The engine is at idle.
File Type: mp3
Old Sep 14, 2017 | 06:06 PM
jwbavalon's Avatar
Spray a bit of water on the drive belt, sounds like a squeaky belt. It will quiet down for a few seconds then make the noise. Solution is to replace the belt.
Old Sep 14, 2017 | 06:38 PM
dshea's Avatar
I'll give it a try. Thanks!
Old Oct 5, 2017 | 06:09 AM
dshea's Avatar
It's the idler pulley starting to go bad. Yesterday, I think it started to freeze up and started stripping the belt. I smelled burnt rubber and saw rubber bits all over the engine bay. The belt itself was in bad shape. I'll be replacing both. Thanks!
rikhemi
Jun 27, 2020 07:36 AM
Spec_Ops2087
Jun 21, 2013 08:23 PM
Allstar
Mar 2, 2007 06:24 AM
grantedS2k
Jun 13, 2005 03:59 AM
grantedS2k
Mar 23, 2005 06:00 PM
