White Smoke
Old Feb 25, 2007 | 09:10 AM
lbk16's Avatar
Default White Smoke
OK, I did a search. I know that it could be a cracked head or bad head gasket. Before I go have a leakdown test/replace my head gasket -- I thought I would ask the question. So, the car smokes when warm -- it also smokes after I turn it off. I can see condensation on the rear bumper. Now, the car has not been driven in a long time. Before I bought it -- it sat for a few months. Since I bought it I have driven it twice (winter in Michigan = no S2000). Also, when I picked it up -- it had almost no gas in it. Is is possible that the white smoke is just a result of the car sitting. I had the oil changed before I took it home -- no sludge. Also, my coolant level is just fine. I do not smell anything sweet from the smoke. The car runs fine -- except for a rough idle (it shakes the shifter knob). What do you guys think. I am new to S2000s. I have owned two Hondas in the past (1997 Acura Integra GS-R and 1999 Honda Prelude) and never had this problem. Any help you can provide would be greatly appreciated. Thanks!
Old Feb 25, 2007 | 09:32 AM
driverunknown's Avatar
could be condensation. This car has big pipes to hold moisture in.
Old Feb 25, 2007 | 10:02 AM
lbk16's Avatar
Let's hope so...
Old Feb 25, 2007 | 12:01 PM
s2kBryan916's Avatar
The shift knob vibrating would most likely be normal. Unless you would describe it as a "violent shake" then I wouldnt worry to much about that.
Is it showing a check engine light?
After running the car for some time, does your coolant level indeed change?
The exhaust system on it is stock?
Old Feb 25, 2007 | 12:03 PM
fltsfshr's Avatar
Check your catalytic converter....
fltsfshr
Old Feb 25, 2007 | 01:44 PM
jdmgpw04's Avatar
well my car does this everyday... but then again i dont have a cat...
Old Feb 25, 2007 | 04:22 PM
lbk16's Avatar
Defintely not a "violent shake," but noticeable.
No CEL.
Nope, coolant level stays the same -- no issues there.
Stock exhaust.
Old Feb 25, 2007 | 04:35 PM
lbk16's Avatar
I will check the coolant level more closely -- but I don't drive it very frequently now. It has been below freezing here for the last 6 weeks.
Old Feb 25, 2007 | 04:36 PM
lbk16's Avatar
fltsfshr
What do you mean by check my cat? Could it be clogged -- could that cause the problem?
Old Feb 25, 2007 | 04:46 PM
gomarlins3's Avatar
It could be some moisture trapped in the exhaust system. Really can't tell until you can get it out for a lengthy drive and possibly burn away the moisture.
