White Smoke help
Hey guys, so my car is puffing white smoke and I am trying to solve it before my next event. Last night I did a compression test and leak down on a warm motor. The car has about 45k miles has a sos super charger pushing 410 and over the past 2 years has been tracked and auto x alot. Trying to figure out the next step I should take in trying to solve this. It is burning oil I am not sure how much since I never logged it. cylinder 3 looks alittle weaker than the others. Cylinder 4 had a darker spark plug. I plan to inspect the retainers tonight. any other things I should be doing next? I am researching now how to inspect retainers and valves since I have not experience with it yet.
compression test
230
238
225
226
leakdown
cylinder 1
4%
cylinder2
4%
cylinder 3
5%-6%
cylinder 4
4%
picture of the spark plugs: Order goes 4-3-2-1 number 4 looks a bit darker maybe 1000 miles on the plugs
compression test
230
238
225
226
leakdown
cylinder 1
4%
cylinder2
4%
cylinder 3
5%-6%
cylinder 4
4%
#1 most likely... but easily detected and by the looks of it your #2 and #3 plugs have been cleaned by something... Coolant?
#2 My opinion your chains stretched, timing is off and late ignition and burning oil but... that leaves a question why #2 and #3 plugs look cleaner
IDK if that tells anyone much of anything. Based on the compression, leak down, and plugs I would have said your car was fine. Now white smoke, that is a different story. Did you figure out what exactly was causing the issue?
