Pretty much. Operating conditions do vary, so the #'s won't always be exact. Keep it in the 12.0-12.5 range and it will be fine AF wise. Outside temp, and altitude can also effect the #'s as well.
Just taking a second look at my dyno sheet,the leanest i see it go is about 12.6 from 7.7k-8.5k,that reading was taken after the cat so it most likely a few tenths richer.Im being VERY cautious!
The idea of using a wideband in place of the narrow band has been discussed in threads recently. Widebands like the PLX, AEM and Techedge have an additional 0-1V output so as to simulate the narrowband signal. You should be able to connect this to your OEM ECU and function normally. The only requirement is that you put a load resistor on the OEM O2 sensors heater circuit so the ECU thinks the narrowband O2 sensor is still there. Otherwise it will throw a CEL.
Why should a load resistor be used if these widebands have the capability to simulate 0-1V narrowband outputs
