wierd engine problem
Old Aug 9, 2010 | 08:55 PM
Rdragon's Avatar
Default wierd engine problem
Ok I noticed this near the begining of the year if I'm idle not moving and I give my car a quick rev to about 2-3 k rpm the rpms will almost go down to zero and the car has died twice on me doing this. Now this is happening if I'm cruise and I put it out of gear regardless of what speed I'm goin foot is not on gas pedal or clutch and car is not in gear just for clarification but the car will do the same thing list about but it feels like the engine is hittig something near my feet. I've done an oil change dif flush radiator flush and tranny flush my car has about 75k miles on it. My mods are a tic single exhaust fromgreddy a k&n intake a invida 70mm textpoipe and a mishomoto radiator. Anyone have any ideas what the problem might be?
Old Aug 9, 2010 | 08:57 PM
Requiem's Avatar
TPS.
Old Aug 19, 2010 | 02:49 PM
Rdragon's Avatar
OK i just swapped out the tps sensor nah the whole throttle body with a sos 70mm and a new intake and new spark plugs and im still getting the same issue, anyone have any ideas?
Old Aug 19, 2010 | 02:51 PM
Requiem's Avatar
MAP wack.
Old Aug 19, 2010 | 05:27 PM
Rdragon's Avatar
did it
Old Aug 19, 2010 | 09:58 PM
BuckyN8's Avatar
I have similar mods, and when I did the map wack it fixed it somewhat.
Old Aug 20, 2010 | 06:59 AM
Rdragon's Avatar
anyone?
Old Aug 20, 2010 | 07:17 AM
cdelena's Avatar
I have always had luck with cleaning the throttle body/egr but many have needed to service the idle air control valve.
Old Aug 20, 2010 | 08:52 AM
rob-2's Avatar
Have you reset the ECU and had it properly relearn idle?
Cruising in N confuses the ECU. The motor should catch itself though.
I would relearn ECU and stop cruising around out of gear.
Mr._ap1
Nov 18, 2010 10:05 AM
nsx04
Mar 26, 2010 12:19 PM
amongmany
Dec 2, 2003 07:26 AM
Kekoa
Jan 18, 2003 12:58 PM
slowpokes2000
Jul 13, 2001 02:15 PM
