Wierd Noise
Old Feb 28, 2006 | 07:01 PM
hondax2000's Avatar
Default Wierd Noise
Hey guys I just got my s2000 and I noticed that if the car is in gear and the rpms are over about 4k and I lef off the cas it makes a loud vibrating sound has anyone ever had this same problem?
Old Feb 28, 2006 | 07:24 PM
xviper's Avatar
You have the well known "clutch decel buzz" (try a search - it's been posted about lots). It's just a noise and has no adverse affects on the operation of the car. This has been around since the car was introduced. You can put in a new clutch disc that may or may not eliminate the buzz.
Old Feb 28, 2006 | 10:13 PM
REVZ TO9's Avatar
Banned
Yah very common problem with the S2K's. I have that darn buzz too.
Old Mar 1, 2006 | 05:41 AM
vtec9's Avatar
Bow to the Buzz!!
Old Mar 1, 2006 | 06:28 AM
Wisconsin S2k's Avatar
TSB 054
Old Mar 1, 2006 | 07:35 PM
hondax2000's Avatar
Well Im glad its not only me. So what parts need to be replaced to fix the problem, also If I bought an extended warenty with my car from a used car dealer will this be covered?
Old Mar 2, 2006 | 05:05 AM
vtec9's Avatar
nope, I doubt they will replace it. The clutch buzz was just a TSB (technical service bulletin), which were released to make technicians aware of certain conditions that arise in some cars, new specifications or procedures for parts, etc. Some dealers replaced the clutch as good will under warranty, but a TSB is not a recall, and I highly doubt an extended warranty will cover it. As mentioned above, the buzz is not a sign of a problem, and it has zero effect on the performance of the car. The only reason to replace it is if you absolutely cannot stand the noise, and even then, there is no guarantee the noise will stop, and if it does, it can come back.
Old Mar 2, 2006 | 10:58 AM
hondax2000's Avatar
I see so what parts to I need to replace to "fix" it?
Old Mar 3, 2006 | 07:32 PM
hondax2000's Avatar
Im gonna have a some one fix it but I just need to know wich parts I need to replace. if anyone knows that would be great
Old Mar 3, 2006 | 07:43 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
The disc.
But do the whole thing while you are in there.
