Will not go past 6k
Old Oct 18, 2017 | 06:33 AM
windhund116's Avatar
I guess you will need to do the VTEC Rocker Arm test, to rule out reassembly issues. Good luck!
VTEC Rocker Arm Test 629
Old Oct 18, 2017 | 11:26 AM
S_DosMil's Avatar
yeah most definitely. I have an appt on the 23rd of this month for inspection of the head. Waiting for my pressure gauge to come in should be here tomorrow.
Old Oct 19, 2017 | 04:06 PM
S_DosMil's Avatar
Well did a pressure test at the pressure sensor. Not sure if Gauge was reading correctly but pressure was basically 0. Not sure if it needs to be driven to get the correct oil pressure since I don’t understand exactly as how the vtec pressure switch works. It goes into the shop Monday for inspection. Any opinions of the pressure would be great. Thanks guys
Old Oct 22, 2017 | 05:32 AM
Chuck S's Avatar
Did ya triple check the VTEC filter screen? (Grasping at straws.)
-- Chuck
Old Oct 22, 2017 | 04:29 PM
S_DosMil's Avatar
-- Chuck
Yup, clean as can be. Going in for inspection tomorrow by shop that rebuild head. Will keep posted.
Old Oct 26, 2017 | 12:45 PM
S_DosMil's Avatar
Wel the car is still at the shop. They have had it since Monday evening. I have not heard from them. Which one makes me slightly happy that it wasn’t something dumb such as a sensor or bad connector. Waiting for the call to see what the issue is. Also to note when we reved it at the shop in neutral it would go past 6k. So the issue only seems to be underload which is odd.
Old Oct 26, 2017 | 01:17 PM
honda4eva89's Avatar
Vtec won't engage while in neutral...it could still be a vtec system issue
Old Oct 27, 2017 | 11:34 AM
S_DosMil's Avatar
Correct I just found it odd that it only does it under load. I never tried free reving it to see if it would go past 6k.
Old Nov 2, 2017 | 03:11 PM
S_DosMil's Avatar
Okay so according to the shop it’s either the manifold or turbo causing a restriction. They took the turbo off and put a regular manifold. Came right back to life. The manifold is just a regular log cast iron manifold. Turbo is a comp turbo 63mm turbo. Never smoked, spun freely, no play. Any ideas what would be causing this restriction?
Old Nov 2, 2017 | 04:19 PM
Does the car have a catalytic converter? I've worked on a supra that was hitting a brick wall around 4500rpms...ended up being a clogged/melted converter
