windshield washer
Old Apr 23, 2007 | 02:18 AM
Skip's Avatar
Default windshield washer
One windshield washer nozzle does not emit/spary on driver's side. The passenger side nozzle does spray normally. Please help?
Old Apr 23, 2007 | 06:09 AM
Saki GT's Avatar
Is the tube connected under the hood?
Old Apr 23, 2007 | 06:42 AM
SpitfireS's Avatar
That ^^ or its blocked by wax or something.
(have you been washing & waxing the car over the weekend?)
Or its blocked by dirt in the washer reservoir making it all the way to the nozzle.
Disconnect the tube and see if water comes out of the tube.
Use a needle to clear blockage from the outside and to aim the spray.
Aim higher then you think you should because the wind while driving will push the spray down.
A lot of text for such a small problem...
Old Apr 23, 2007 | 07:28 AM
rustywave's Avatar
this probably isn't your problem, but i had sort of a similar issue before. the driver's side nozzle would take awhile or not spray as much (like all winter)...but after i filled up the washer fluid tank again they both sprayed fine.
Old Apr 23, 2007 | 09:25 AM
Skip's Avatar
I thank you all for your insight. I will post again after post repair attempt. Membership consultation within this website is an invaluable tool for ownership of an S2k!
Old Apr 23, 2007 | 10:20 AM
freq's Avatar
Skip, you're like my neighbor. Me and about 6 other S2000 owners call the Lehigh Valley home. Why not post up in the Del-Val Forum and come to one of our meets?
Old Apr 23, 2007 | 04:54 PM
Yflyer's Avatar
I own three first generation Odyssey's (don't ask) and they use the indentical washer jet. They also clog. Disconnect the hose from the jet, the gently pop the jet off the hood (there is a pinch-type release on the under side). Soak the jet in water, then backflush it with a rubber syringe or gently clean it with a fine gauge wire. You would be surprised at the amount of crap that comes out.
tim62
Dec 23, 2007 01:05 PM
uppitychick
Jan 14, 2005 09:51 AM
phoenix9999
Sep 9, 2004 02:07 PM
DJ Qube
Sep 4, 2003 08:03 AM
ITRbroham
Jul 24, 2002 08:41 AM
