Yellow Box Installed=Check Engine Light??
Old Nov 9, 2003 | 06:37 PM
  #71
Defender's Avatar
[QUOTE]Originally posted by PsychoBen
Old Nov 9, 2003 | 07:11 PM
  #72
Pinky's Avatar
It's some tight spaces under there so things can get confusing easily. I bet it's the same wires.
Rick: I would suggest that you give the picture above as the way of choice for most as it is the way I did it and as seen many others.
BTW: I am at ~19.75%. Though not running stock tires but rolling distance is supposed to be the same. GPS verified accurate.
Old Nov 12, 2003 | 12:33 PM
  #73
Gernby's Avatar
Former Sponsor
Has anyone checked to see what the ECU thinks the speed is using an OBD-II scan tool after connecting the YB to C101?
Old Mar 2, 2004 | 09:55 AM
  #74
Strike's Avatar
I just installed my yellow box. I followed Modifry's instructions exactly and used the third wire as Turbo_pwr and Defender recommended. I got the same results as Slick Rick. No speed correction and the lights on the yellow box continued to flash even when moving. I even disconnected the yellow box thinking that if I disrupt the signal to the speedo it would stop working. But the speedo works fine even if the third wire is an open. I then tried the yellow box using the fourth wire and it worked perfectly. So it's the fourth wire that should be used - this wire is blue with a white stripe as opposed to the third wire which is white with a blue stripe. Please don't anyone take this post the wrong way. I greatly appreciate the information I got from this thread. I just wanted to post this information for future users, especially since there are a lot of us who recently purchased the 4.57 gears.
Old Mar 2, 2004 | 09:58 AM
  #75
Strike's Avatar
This occurred to me as well. I'm going to get together with a buddy and his handheld GPS to fine tune my yellow box. He also has an OBD-II scanner so we'll check this out.
Old Mar 2, 2004 | 10:05 AM
  #76
Ztec's Avatar
I used the fourth wire as well and had a correction of 12%
no problems as of yet!
Old Mar 2, 2004 | 11:02 AM
  #77
Defender's Avatar
[QUOTE]Originally posted by Strike
Old Mar 2, 2004 | 12:31 PM
  #78
Sideways's Avatar
I took mine out before installing the AEM EMS. Turns out the AEM EMS can't modify the speedo reading so I put it back in and after a few days it quit working. Long story short it was a poor power connection. It works fine with the AEM EMS now.
Old Mar 2, 2004 | 12:45 PM
  #79
Gernby's Avatar
Former Sponsor
[QUOTE]Originally posted by Sideways
Old May 30, 2004 | 06:33 PM
  #80
Venomous S's Avatar
[QUOTE]Originally posted by modifry
