Clamp on lights
I need to buy some clamp on lights to put in my garage for some supplemental lighting for my detailing business. I looked on line and the reviews were all over the place. I would pay more for a good light with a reflector that can handle some extra wattage. Any advice would be appreciated.
I have one big LED light with a big magnet if I work on mechanical issues under the car or under the hood but I doubt that's what you are concerned with.
I’m not certain how you intend on using the lights, but I think you already have a preconceived opinion.
Home Depot is probably a good source with a reasonable cost. When I used to paint, color sand and buff cars and found that a bright florescent lights with omni-directional lighting gave unrealistic effects — an bright incandescent bulb within a reflector and then fitted with a diffuser provided the best results. A light stand was used so that I could adjust lighting heights and its proximity to the car(s).
gary
gary
gary
gary
Thanks.
gary
gary
Thanks.
gary
I used these. Put the feet into DIY holders mounted on the wall. Then, you can remove the light if needed elsewhere.
http://www.amazon.com/Snap-922261-20...=snap+on+light
Originally Posted by S2KRAY' timestamp='1449089462' post='23818071
[quote name='skunkworks' timestamp='1449081856' post='23817935']
gary
gary
Thanks.
gary
[/quote]I picked up 2 clamp on lights from Home Depot and installed 150w. flood lights. Super bright and the dark areas are no longer an issue.
