Coke or Water...
WATER OR COKE?
> This is really an eye opener...Water or Coke?
> We all know that water is important but, I've never seen it written down like this before.
> WATER
> 1. 75% of Americans are chronically dehydrated.
> 2. In 37% of Americans, the thirst mechanism is so weak that it is often mistaken for hunger.
> 3. Even MILD dehydration will slow down one's metabolism as much as 3%.
> 4. One glass of water will shut down midnight hunger pangs for almost 100% of the dieters studied in a University of Washington study.
> 5. Lack of water, the #1 trigger of daytime fatigue.
> 6. Preliminary research indicates that 8-10 glasses of water a day could significantly ease back and joint pain for up to 80% of sufferers.
> 7. A mere 2% drop in body water can trigger fuzzy short-term memory, trouble with basic math, and difficulty focusing on the computer screen or on a printed page.
> 8. Drinking 5 glasses of water daily decreases the risk of colon cancer by 45%, plus it can slash the risk of breast cancer by 79%, and one is 50% less likely to develop bladder cancer.
> And now for the properties of COKE:
> 1. In many states (in the USA) the highway patrol carries two gallons of coke in the truck to remove blood from the highway after a car accident.
> 2. You can put a T-bone steak in a bowl of coke and it will be gone in two days.
> 3. To clean a toilet: Pour a can of Coca-Cola into the toilet bowl and let the "real thing" sit for one hour, then flush clean. The citric acid in Coke removes stains from vitreous China.
> 4. To remove rust spots from chrome car bumpers: Rub the bumper with a rumpled-up piece of Reynolds Wrap aluminum foil dipped in Coca-Cola.
> 5. To clean corrosion from car battery terminals:
> Pour a can of Coca-Cola over the terminals to bubble away the corrosion.
> 6. To loosen a rusted bolt: Applying a cloth soaked in Coca-Cola to the rusted bolt for several minutes.
> 7. To bake a moist ham: Empty a can of Coca-Cola into the baking pan,wrap the ham in aluminum foil, and bake. Thirty minutes before the ham is finished, remove the foil, allowing the drippings to mix with the Coke for a sumptuous brown gravy.
> 8. To remove grease from clothes: Empty a can of coke into a load of greasy clothes, add detergent, and run through a regular cycle. The Coca-Cola will help loosen grease stains.
> 9. It will also clean road haze from your windshield.
> For Your Info:
> 1. The active ingredient in Coke is phosphoric acid. Its pH is 2.8.
> It will dissolve a nail in about 4 days.
> Phosphoric acid also leaches calcium from bones and is a major contributor to the rising increase in osteoporosis.
> 2. To carry Coca-Cola syrup (the concentrate) the commercial truck must use the Hazardous material place cards reserved for Highly corrosive materials.
> 3. The distributors of coke have been using it to clean the engines of their trucks for about 20 years!
> Now the question is , would you like a coke or a glass of water?
> WATER
> For Your Info:
I generally drink water after I'm done with the morning coffee ... if I do choose to consume a soft-drink (on rare occasions) it would be a Dr Pepper ... because I cannot drink coke without a bourbon mixer ... coke just doesn't taste right without it.
For a long time, I was a Coke drinker. Then, I switched to Diet Coke in an effort to lose some weight. At first it tasted awefully, well, "tasteless" but I got used to it.
Fast forward to now, I was sick for a while and stayed off the soft drinks and all the bad stuff. I've been drinking water for the last 7-8 months or so. On a few occasioins where I had been out and no water was available, I got myself Diet Coke and man, it tasted awefully sweet to me. I guess everything is relative.
Don't think I can go back to Coke or Diet Coke. Water- it's good for ya.
