General Car Question
Old Dec 14, 2009 | 03:39 PM
JonasM's Avatar
Default General Car Question
A member of another list I'm on posted this. Can someone answer his question?
I have a 1992 Volvo 940 GL. It has been leaking water for months and I've been told "the part is on backorder" several several times. So today, I finally find *precisely* where the leak is. It's in the Heater Core flow valve -- which has a little vacuum thingamajig on it to divert water to the heater core whenever you engage the heater.
With a spindle from an old package of CD-RWs and a little elbow grease, I managed to *BYPASS* that valve... NOT the heater core, just the VALVE. Upside -- it doesn't spew water everywhere and overheat. Downside: there is now hot water flowing through the heater core at all times. Thus my question: is there any real downside to bypassing the heater core flow valve? Eg. should I worry that hot engine water is flowing through the heater core even when the heat's not running?
JonasM
Old Dec 14, 2009 | 05:29 PM
RC - Ryder's Avatar
^^ I've had something similar on a Jeep Cherokee some years ago. I didn't care about the car, really. It was never an issue in the winter months, and in the summer, I simply took the heater hoses to the firewall off, inserted a proper diameter metal tube and short circuited it in the engine bay. That created no problems either.
Old Dec 14, 2009 | 11:30 PM
PanteraKitty's Avatar
Just put shut-off valves to the heater hoses at the engine. We do that for racing in Panteras because the hoses run through the console and if a hose broke, a cabin full of steam and hot water would distract the driver during a race, especially if that hot water was spraying all over your right leg.
Old Dec 15, 2009 | 05:20 AM
Legal Bill's Avatar
Or just let it run through the heater core at all times. It may get a bit warm inside the car in the summer.
Option 2. Go to a junk yard and get one of a wreck.
Old Dec 15, 2009 | 09:47 AM
Vanishing Point's Avatar
The only downside to this fix is it may take longer for the car to warm up in the winter months. But it will work with no detrimental effects to the vehicle.
Old Dec 15, 2009 | 11:09 AM
dlq04's Avatar
The point of the shutoff valve is to open it in the winter; there's no reason for it to slow things down. I know, I've done it.
Old Dec 15, 2009 | 12:10 PM
Sorry for the confusion.
I used the wrong quote to agree to, I should have used legal Bill's. By having the cold coolant circulate through the heater core in addition to the radiator, it will tend to lengthen the warm up period.
**Jay-V**
Apr 1, 2007 09:36 PM
VTECnDaRed1
Apr 4, 2005 04:37 AM
MistaSnipes
Jun 19, 2004 02:59 PM
