I was thinking of getting that but someone told me it would block too much air flow while driving hard... ?
Dozens and dozens of people have the grill inserts including several Vintage folks. As far as I can recall I've only heard of one person, a racer in CA, who had one and removed it for that reason. His car as I recall was modified as well. Come spring with my new tires and race pads I will give it a test to know for sure. I thought I'd do something a little different and came up with the Honda idea.
Originally Posted by SheDrivesIt,Feb 7 2008, 12:15 PM
What brand of grille insert is that?
Grille-Tech. Grille-Tech.com. It's a light weight plastic. I also got the side inserts as well. The larger insert comes with black plastic ties. The sides with stainless steel screws. To avoid using the screws I drilled two small holes in two corners and used black plastic ties on the sides.
