303 Protectant...
Old May 14, 2007 | 10:57 PM
  #21
Silvers808's Avatar
Originally Posted by MikeyC,May 9 2007, 02:26 AM
I would also add . . .
-wiper arms
that's about all I can think of.
does it not affect the paint on the arms???
Old May 14, 2007 | 11:04 PM
  #22
dolebludger's Avatar
No it does not harm the paint on the wiper arms.
And to answer an earlier question, 303 aerospace protectant DOES have some cleaning ability. Now if something is really filthy, 303 does sell a cleaner, and there are other cleaners out there. If it's filthy, use them. But if you only have some smudges and stuff like that , yes, 303 will clean them.
Old May 15, 2007 | 12:53 AM
  #23
WindchaserS2K's Avatar
Originally Posted by dolebludger,May 13 2007, 03:31 PM
Oh, Yeah, I forgot one of the most important uses. For those of you with '00 or '01 s2ks with the plastic rear window, soak it down for a few hours with 303 a couple or three times a year, and clean it off with Plexus. This will keep your window soft and pliable, and more resistant to cracking and scratching.
So soak the back plastic window and let it dry???
Old May 15, 2007 | 01:22 AM
  #24
Yeah. I put on the 303 with a piece of 1" thick foam, like they sell in sheets at fabric stores. I lay it on heavy, and particularly in the hot summer months, let it soak in over night. Then I wipe it off with a microfiber. There will still be smears left. Then I use Plexus to got those smears off. The end result is a soft as new plastic window. And usuallly as clear as new. If there are any scratches or cloudiness that has not been removed, I use a ROB with Meguair's PlasticX or similar abrasive polish for plastics, But do this only after you have softened the window as I have described. If you apply a ROB to a hardened plastic window, you might break it.
Old May 15, 2007 | 05:01 AM
  #25
MikeyC's Avatar
Sorry to go off topic, but I am SO glad I did not buy this car when it came with a plastic window. What a PITA plastic windows are. I find it annoying enough when I have to contort to clean the inside of my glass rear window.
Old May 15, 2007 | 09:35 AM
  #26
philbert's Avatar
is the Wolfsteins RaggTopp Vinyl Protectant roughly equivalent to 303? Is there a general preference for 303 due to quality or availability? Pricing seems comparable.
Diabolus2k, you mentioned using Vinylex. Any particular reason for this over one of the others?
Old May 15, 2007 | 10:10 AM
  #27
vtec9's Avatar
Yes I believe they are roughly equivalent. I choose 303 over Raggtopp though since I know for a fact it can be used on practically every rubber, plastic, and vinyl part on the car.
I never thought to use it on the plastic rear window though. I've been using Novus number 1 and 2 to clean, protect, and remove scratches and haze. It works pretty well.. I'm going to try soaking with 303, then hitting it the novus now. Thanks
Old May 18, 2007 | 06:29 PM
  #28
just_dung's Avatar
Originally Posted by dolebludger,May 14 2007, 08:55 AM
Our tops are vinyl. No doubt about it.
awesome! now i just need to finish finals so I can spend time w/ the S
Thanks for the info again.
Old May 18, 2007 | 08:19 PM
  #29
chuhsi's Avatar
Can I use 303 to protect a Bride seat?
Old May 18, 2007 | 08:56 PM
  #30
vtec9's Avatar
What's it made from?
