303 Protectant and Cleaner
Old Oct 17, 2006 | 09:07 AM
JDMPONY00's Avatar
Default 303 Protectant and Cleaner
I ordered a 303 kit today for a vinyl top, correct me if im worng but the S2000's soft top is vinyl right?
Old Oct 17, 2006 | 09:11 AM
MikeyC's Avatar
No correction needed. You are 100% correct. The OEM top is vinyl.
Old Oct 17, 2006 | 09:13 AM
JDMPONY00's Avatar
Thats what I thought but I figured I would ask before the order shipped, Thanks.
Old Oct 17, 2006 | 09:20 AM
wanabe's Avatar
it is confusing... especially since honda calls it "top cloth"!!
dont know why they dont call it top material or top vinyl-
303 is a good product for our tops- so is vinylex or raggtopp for vinyl tops (raggtop also makes a protectant for cloth tops- be happy that you dont have to use that stuff!! you have to mask the entire car other than the top cause its an aerosol).
Old Oct 17, 2006 | 09:40 AM
JDMPONY00's Avatar
Whats the best way to apply the protectant, I was just going to spray it on a wax applicator and rub it on the top? Also is there any harm if I do get it on the paint or glass?
Old Oct 17, 2006 | 10:02 AM
wanabe's Avatar
you want to make sure not to get it on the paint-
soak an applicator or rag away from the car. rub it in to the top well- keep the rag wet.
let it sit for awhile- i do the rest of the car at this point. then buff off the top with a clean dry rag. i often follow that by another dry rag just to make sure i got off all excess in case of rain (to keep rain from washing it onto the paint). after your first buff you can inspect and can tell whether you need a second buff or not- you usually will not- its only when i really soak the top that i need two.
Old Oct 19, 2006 | 05:54 AM
abalto's Avatar
The 2005/2006 tops are vinyl? Feels like cloth to me.
Old Oct 19, 2006 | 06:07 AM
00CivicSi's Avatar
[QUOTE=abalto,Oct 19 2006, 09:54 AM] The 2005/2006 tops are vinyl?
Old Oct 19, 2006 | 06:14 AM
00CivicSi's Avatar
Not as confusing as the 350Z Roadster tops... At least on s2ki we have a definitive answer. On the Z forums there are people on both sides that are convinced they are right.
I know this only because a coworker picked up a ZR and asked me advice about the top. Naturally, I told him he needed to find out what kind of material it is. He was convinced it was cloth despite looking all over the Internet, checking with the dealership, and contacting other resources which never gave a straight answer. I think we determined it was vinyl coated cloth as ours is when we finally got our cars side-by-side. The ZR material seems very similar to the S2000 material (and very different from known cloth tops).
He's used RaggTopp for vinyl with success.
__________________________________________________ ___
Summary, in case my post is confusing.
S2000 OEM top material - Use vinyl cleaning/protecting products.
350ZR OEM top material - Don't know for certain, but I'm convinced it's similar to the S2000 and that vinyl products should be used.
Old Oct 19, 2006 | 06:43 AM
MikeyC's Avatar
Originally Posted by 00CivicSi,Oct 19 2006, 10:07 AM
Actually, all OEM S2000 tops are vinyl coated cloth
While you're right that our tops are vinyl it's not because they are vinyl coated cloth. The tops are made from a woven PVC. They take strands of PVC (vinyl) and weave them into a sheet to make the top. This is why our tops look so much like cloth tops. Our tops are woven just like a fabric top. Most vinyl tops as you mention are simply a solid vinyl sheet with some texture molded into them.
