Applying Paste Wax
Old Oct 5, 2007 | 09:27 AM
Oake's Avatar
Default Applying Paste Wax
I've always used liquid wax is the past ... but this weekend, I'm taking the plunge into the P21S paste wax world ... and was wondering the correct method in applying it (I tried a search but came up with nothing really useable). Do I just dip the applicator into the container to get the wax out? Suggestions, opinions?
Oake
Old Oct 5, 2007 | 10:44 AM
wanabe's Avatar
with p21s by hand, yes
wipe on a small area as the air flows over the car (not in circles)... with the applicator that come with it.
as soon as you finish that section, wipe it off
if you want to use a machine, with a rubber glove turn the p21s over and tap it- the wax will fall out in your hand- apply to the pad and put it back in the can. same thing- do a small section. nice to have an assistant here, cause as you finish with one area your assistant can follow up with the removal.
let it cure and its done!!
Old Oct 6, 2007 | 08:59 PM
Ch0pper's Avatar
What is the cure time for P21s, wannabe ?
Old Oct 7, 2007 | 04:58 PM
wanabe's Avatar
cure times for any product depend on several variables...
the best condition seems to be warm and not too humid. and inside a garage is also best cause the weather condtions are more even.
the worst are either extreme- too hot or too cold with humidity.
given the above, the general rule of thumb for just about any lsp (wax or synthetic)is 24 hours...
p21s will fully harden in less than 24 hours, but that is a safe rule of thumb.
easiest way to put on a second layer of wax (does not good beyond that) is to do it the next time you wash the car.
Old Oct 7, 2007 | 07:02 PM
FMINUS's Avatar
I always like to do a final wipedown with icewater when using paste waxes
Old Oct 7, 2007 | 10:23 PM
Currahee474's Avatar
Yes. Humidity=bad it takes the wax forever to dry, and it wont dry all the way leaving it wet and you wont be able to adhere the wax to the car.
I always used a sponge and did it in tight small 4 inch circular patterns, and I do 1/2 the car at a time, then buffing it out with a microfiber towel.
Old Oct 10, 2007 | 09:24 AM
Oake's Avatar
Since the weather's been crappy and will continue to be kinda cold, is there any advantage to applying multiple coats of the wax?
niahuynh
Mar 25, 2010 12:43 PM
dtmcnamara
Mar 19, 2008 03:10 PM
JBERRY2728
Apr 22, 2005 10:50 AM
boofus
Mar 26, 2003 04:52 PM
TTSUPRA
May 23, 2002 01:48 AM
