Chetah spots!
What are they and how do I get rid of them?
I washed the rims with dishwashing soap to get the brake dust off, and this is what I found underneath. Tried claybar, didn't work. Tried scratching them off with my nails, didn't work.
Looks like they're only present on the front rims.
water spots maybe...
i hope they are not etch spots (can you feel the edges with your fingernail?)-
have you tried a non-acid wheel cleaner?
do not use acid on the wheels cause they are clear coated...
It's hard to tell from the photo, but what wanabe said - can you feel the edges? If so, then I'd be inclined to think that the clearcoat has been compromised somehow. If you can't feel these spots, try a non-abrasive cleaner polish like Klasse AIO with a soft cotton rag (after washing the wheel) and see if that helps any. Either that or clay.
Originally Posted by Ubetit,Sep 18 2005, 10:14 AM
Looks like etching. Even the rest of the finish looks weird. Are these 04-05 oem wheels?
the finish on your wheels looks kind of dull. Did you take this picture in a dark garage or at night using the flash on your camera? I'm think if you took the picture in the dark the flash might have "washed out" the picture.
I got some similar spotting off my wife's '04 RSX using Mothers chrome polish. The bottle looks like this :
Of course, if those really are deep etches in the clear coat, this probably won't fix it permanently, but should at least get you cleaner looking for a bit.
