Clay Bar on my headlights ..............
Old Mar 22, 2008 | 06:20 PM
freq's Avatar
Thumbs up Clay Bar on my headlights ..............
Just checking, too lazy to walk to the garage and read the packaging.
Old Mar 22, 2008 | 06:23 PM
wanabe's Avatar
my bro moderator-
be very careful and make sure its a mild clay... no circular motions, especially on soft parts like plastic headlights.
i would test a small area first. and plenty of lube- very mild pressure.
prob would follow it up with a plastic polish- i like the power ball for that.
btw, only use clay for clay solutions (the plastic feels rough)- plastic does not have to be clayed usually... polish is more often what it needs.
what are you trying to fix?
Old Mar 22, 2008 | 07:58 PM
shotiable's Avatar
i clay my headlights, i have no problems
Old Mar 23, 2008 | 05:50 AM
freq's Avatar
Angry
I bought some used AP-2 headlights and they have some lite scatches since day 1 from shipping and such and from removing them from the donor car.
There was also some tape residue from trackdays and such. I have polished them up by hand using some :
The tape residue is now gone BUT the lite scratches remain.
I could install them the way they are now and be mostly satisfied but........ I do have that badge in my sig that MUST be honored.
I could only find 1500 grit sand paper at my h/w store. Even the local Auto Body shop didn't have 2000 or 3000 grit as the owner said they no longer wet-sand.
I do have the 3 step Novus collection but I think I tried that when I first go the headlights w/ limited results.
Old Mar 23, 2008 | 06:21 AM
Ubetit's Avatar
My local auto body and paint stocks to 3000 grit. You can order micromesh up to 12,000 grit.
I use the rotary and regular polish on mine. There have only been 1 set of headlights so far that I couldn't save. If the scratches are deep there isn't much you can do.
Old Mar 23, 2008 | 08:19 AM
freq's Avatar
[QUOTE=Ubetit,Mar 23 2008, 09:21 AM] I use the rotary and regular polish on mine.
Old Mar 23, 2008 | 08:53 AM
HankookS2K's Avatar
the clay bar is not going to diminish scratches.
if they are what you say hairline scratches. just use a 3000grit sandpaper and wetsand and buff out with either a pc or rotary
Old Mar 23, 2008 | 11:19 AM
freq's Avatar
Thanks Hankook, I did review your stickied "How To" on headlights.
I'll have more questions, after I acquire some 3000.
Thanks.
Old Mar 24, 2008 | 04:48 AM
Ubetit's Avatar
Originally Posted by freq,Mar 23 2008, 12:19 PM
So you do or do not use the wet-sanding technique for minor hairline sratches? Should I continue my quest for sand paper or resort to solely my PC and polish?
Either method is fine. I prefer the machine method but i'm not sure the PC has enough power to do it though . I use 4" pads on the rotary
Old Mar 24, 2008 | 07:12 AM
chillout18's Avatar
you can even use 2000 grit ....thats what I use if I need to wetsand clearcoat...3000 mite be hard to find
