Clay Bars?
Old Dec 10, 2002 | 05:41 PM
CivicMan86's Avatar
Default Clay Bars?
Ok well Im a clean freak with my car. I have heard alot about these clay bars. Are they really worth doing? I mean can you actually see a dramatic difrence in the paint of your car? I have had tons of compliments on my cars shine but Im always lookin for ways to imrpove. You all seem to know you cleaning supplies the best. Thanks
Old Dec 10, 2002 | 08:34 PM
wanabe's Avatar
clay bars remove contamination and makes rough and cratered surfaces smooth as glass. so if your car sits outside, it can probably benefit from claying every once in a while... mine is usually inside and almost always covered- so it wont need to be clayed for awhile. you can feel the contamination by lightly rubbing a finger across your paint. or if you have clay, you can use it to test the surface too. if it drags, the car can benefit from being clayed. if it slides easily over the surface, its probably pretty much uncontaminated.
Old Dec 11, 2002 | 05:37 AM
STreece's Avatar
Anytime you are looking for optimum results...clay the car! It doesn't matter if you're going to apply Zaino or a wax based product to the finish, the surface preparation will affect the end result. Even a new car will benefit from clay. The reason is that clay removes contaminants from the finish that can not be washed away.
If you feel the finish with the backs of your fingers, it will probably feel smooth. A more exact test is to then wrap cellophane around your fingers and then lightly move them across the surface. Where it felt smooth with your fingers, the cellophane lets you determine the true condition of the surface. It will probably feel rough. That roughness is contamination that can not be washed off. The clay will remove that, making the surface slicker, i.e., more reflective and help the car stay cleaner because there are fewer imperfections on the finish for dirt to adhere to.
How often you clay is purely subjective. Some folks will clay once and never look back. Others do it every 6 or 12 months.
Old Dec 11, 2002 | 05:33 PM
VinceD's Avatar
[QUOTE]Originally posted by CivicMan86
[B]I have heard alot about these clay bars...can you actually see a dramatic difrence in the paint of your car?
Old Dec 12, 2002 | 07:46 PM
CivicMan86's Avatar
Ok thanks for the info guys. I will try to pick up a bar near spring when I can get some money and time.
Old Dec 14, 2002 | 11:04 AM
TriaXenginE's Avatar
i agree with everyone here. after you use the claybar the paint will look like liquid glass. everything is sooo smooth.
Old Dec 15, 2002 | 10:16 PM
RoBD305's Avatar
Is there any need to clay the car if you are picking one up brand new straightfrom the truck
RoBD305's Avatar
Old Dec 16, 2002 | 12:53 AM
sumir brahmbhatt's Avatar
yes rail dust and contaminants from traveling will be embeded in the paint
Old Dec 17, 2002 | 03:19 AM
bloodwynch's Avatar
Another thumbs up for the claybar from me. It's worth the extra cost and time to prep your car before applying wax.
