Cleaning Rims
Old Jun 7, 2006 | 12:21 AM
LemonS2k's Avatar
Default Cleaning Rims
There is some really tough brake dust embed on my wheels... I tried using many products to remove those brak dusts...but it just won't come off. I even tried using P21s Wheel Cleaner Gel... and leaving it on for 2 hours...
those brake dust just won't come off.....
any idea how to remove them?... been there for months... just won't off... please HELP.....!! THANKS!!
Old Jun 7, 2006 | 08:04 AM
MikeyC's Avatar
I have two suggestions for you.
First, try using detailing clay on your wheels. Removing bonded contaminants is what detailing clay is designed to do. After you're done make sure to throw away the piece of clay you used as it will be filled with brake dust. So, you won't want to use it on paint.
Second, try a stronger wheel cleaner. P21S is effective but still rather gentle. I HIGHLY recommend you get yourself some Meguiar's Wheel Brightener. This stuff will take off almost anything. Dilute it 3:1 for EXTREME cleaning and DO NOT let this stuff dry on your wheels. Use Wheel Brightener once then seal your wheels. After that you should be able to clean them with car wash soap for a few months.
Old Jun 7, 2006 | 10:15 AM
wanabe's Avatar
agree 100% with mikeyc-
only would add that i wonder if its really brake dust, or if you might now have some pitting or corrosion.
got pics and really close pics?
Old Jun 7, 2006 | 02:15 PM
robs_silver_s2k's Avatar
agree with Wannabe might be pitting/corrosion
Old Jun 7, 2006 | 04:31 PM
MikeyC's Avatar
Good point! I didn't think of that.
Old Jun 9, 2006 | 09:25 AM
ONEQUIKSTI's Avatar
What do you seal your wheels with? Thanx!
Old Jun 9, 2006 | 03:59 PM
Ajserrano's Avatar
I'm having exactely the same problem with my rims (3months since last wash). I tried the clay and mothers metal polish.
Can it be pitting or rust? Aren't the rims aluminum? If it is pitting how do I correct it? Should I use a dremel with metal polish.
Thanks in advance.
Old Jun 10, 2006 | 04:06 AM
Ajserrano's Avatar
bump
Old Jun 10, 2006 | 07:51 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
I use Klasse AIO,topped with a few coats of P21S;dust does'nt stick to the wheels.
Old Jun 10, 2006 | 08:16 PM
animeS2K's Avatar
Thanks in advance.
The rims are aluminum, but they're clearcoated. The rust would be from your brake rotors - brake dust is powdered pad material and rotor material.
Metal polish won't do anything for the wheels, since they are clearcoated. It's essentially the same as the clearcoat on your paint. I would not recommend a dremel on your wheels.
A strong wheel cleaner as MikeyC has recommended and a pressure washer are a good combo, as long as you don't use TOO MUCH pressure. I've got to get some pics of my sister's wheels that I did with that combo. I didn't think they were ever going to come clean.
