Detail from Hell
Old Jul 23, 2009 | 03:25 AM
S2KRAY's Avatar
Active Streak: 30 Days
Top Answer: 1
Default Detail from Hell
I detailed an elderly ladies 5 year old Toyota Avalon yesterday. She parks it outside under a tree and has not had it detailed for 5 years. The sap was unbelieveable. I tried tarminator and then a light sample of laquer thinner but it didnt budge. I ultimately had to clay bar the entire car and it took me 4 hours as it was everywhere. My fingers were numb last night and at 65 I have a little arthuritis so I was popping Tylenol with arthuritis every 4 hours. Is there an easier way to remove this stuff. I know my detail supplier stocks a more aggressive clay and I saw that Griots sells an attachment that fits on the Porter Cable DA machine I use. The clay fits inside a pad and allows for machine use. The car came out great after getting all of the sap off then polish and Klasse but it took me 10 hours. I could barely get my hands around the multiple Corona's I drank after I got home.
Old Jul 23, 2009 | 03:43 AM
SpecC's Avatar
i think letting it soak in some APC would help
Old Jul 23, 2009 | 04:49 AM
akimel's Avatar
WD-40 was recently recommended to me for tree sap.
Old Jul 23, 2009 | 12:08 PM
slanguage's Avatar
This is when plastic razor blades are your friend. I just removed all the sap and bird doodoo of the wifeys van a coupe weeks ago.
Spray the area with Tarminator, let dwell for about 2 minutes, scrap with plastic razor blade, spray again and wipe with a mf towel. Then proceed to clay.
Hope this helps, and hope your hands feel better.
Old Jul 23, 2009 | 04:32 PM
S2KRAY's Avatar
Top Answer: 1
I will definitely experiment with these suggestions, where do you purchase plastic razor blades. Hands are better today, thanks guys.
Old Jul 23, 2009 | 05:32 PM
RedY2KS2k's Avatar
I've had good luck rubbing a mechanic's waterless hand cleaner over the paint and letting it sit for a while, even overnight. It's thick enough to cling to vertical surfaces, rinses off with water, and dissolves most saps, greases, etc.
Of course, NO PUMICE, and I prefer the old-fashioned stinky stuff to the newer citrus.
Of course, I'm adding the standard "test in an inconspicuous place before using" disclaimer.
Old Aug 3, 2009 | 04:31 PM
gofast182's Avatar
Just went through the sap saga with my '07 Accord. 70% isopropyl rubbing alcohol and a mirofiber towel took it off easily without damaging the finish.
Old Aug 3, 2009 | 06:02 PM
wanabe's Avatar
i was gonna suggest the beer remedy for your hands, but i see that you already got that one !!
and the technical stuff was handled by our fellow wackos above-
keviinbraah017
Mar 21, 2012 12:31 PM
mattfeet
May 13, 2007 06:42 AM
SPFSkyline
Mar 29, 2006 06:23 PM
S2Koupe
Mar 27, 2006 10:37 AM
ultrA_Cowboy
Nov 26, 2004 07:51 AM
